Hi,i have a vaillant turbomax combi boiler,the radiator side is working well but when running hot tap the boiler kicks in for about 5 seconds ,hot water starts to flow then boiler cuts out,water runs cold agin then boiler starts and this cycle repeats.can anyone help?thanks in advance.mark.
  • 13 Answers
Which turbomax, as there a two different models. The more modern one, with the brass CPL diverter valve, located at the front left of the boiler, was very prone sticking & jamming, this would restrict flow through the hot water circuit in the boiler, and cause cycling. Vaillant actually modified the diverter. You can identify, if it is the old type, as there is a very small hole in the middle of the diverter on the old ones, probable no more than 1mm-2mm wide. The modfied one, is much bigger approx 5mm wide. If old type, replace as this usally sorts the problem
Posted on Mar 03, 2009
I had this. Open up the main case, take the second inner case front off to expose the boiler.
Clean the thermocouple which detects the flame being lit with some steel wool held with needle nose pliers. It will be all sooty and will turn off the gas as a safety precaution if it does not detect heat fast enough.
Don't listen to the gas man who will say "needs a new circuit board mate" as this is usually a stock response.
Posted on Jan 05, 2009
Hi can anybody help,i have a vaillant combi boiler and i cannot turn the heating off on the radiators can anbody help cheers!
If you they won't go off when your timer is off. There's a possibility it's clock keeping it on although its turned off, which is fairly rare. However depending in which model of Vaillant you have, if your boiler has a hot water pre-heat on it. Some models which have this the diverter was prone for sticking thus leaving the port for the radiators open when in hot water mode.
Oct 03, 2013 | Heating & Cooling
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
Vaillant Combi boiler
LOOK ON ONE OF THE COVERS 75% OF ALL CODES ARE ON THE INSIDE OF A COVER FOR SERVICE TECHS, NOT MUCH HELP BUT HOPE IT LEADS YOU DOWN THE RIGHT PATH
Jan 23, 2010 | Heating & Cooling
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
Vaillant combi boiler,dirty water comes out of hot and cold taps ,just been serviced by british gas,could you tell me the problem
Hi ,
Can you please tell me the model of the vaillant, and the approx age?
I can solve this problem
I await your reply
Thanks
Steve :)
Jul 16, 2009 | Water Heaters
Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Apr 13, 2009 | Air Purifiers
Clock on comi boiler
it may be the preheat setting on the boiler for the hot water circuit. do the radiators get hot when the boiler fires up with the time clock off ? if not then there is nothing to worry about if it is only on for a short time.
Jan 04, 2009 | Heating & Cooling
Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
Dec 31, 2008 | Heating & Cooling
Heating, but no hot water on a vaillant turbomax 28 combi
the problem is the diverter valve unit, source a corgi engineer to fit new one, cost for valve approx 80 quid +fitting
Kindly
Richie
Dec 15, 2008 | Water Heaters
Vaillant Ecotec combi boiler - radiators working but no hot water flow to taps
David,
The fact that you're getting a little burst of domestic hot water suggests that the boiler is capable of circulating hot primary loop water through the heat exchanger, but doesn't necessarily do so when it needs to.
What seems to be lacking is a recognition that domestic hot water is now being drawn off, and that the boiler needs to fire up and divert the primary flow through the heat exchanger.
A good place to start might be the flow switch (usually in the bottom of the boiler, where the cold water supply comes in) or the electrical connections to it.
A.
Oct 05, 2008 | Heating & Cooling
Heating & Cooling Logo
736 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
