The lens is a Nikon AF 28-90mm macro D. I bought a used N75 a couple weeks ago and everything works fine, but last night I had the lens off the camera body and was giving it a cleaning, I noticed a little switch near the lens that seems to move left and right. For some reason I moved that switch left and then realized it wont move back to the right. Then when I put the lens back on the camera, everything looks very dark through the viewfinder, I looked through my instruction manual but didn't find any help for this.
What I think happened is that switch set the lens aperture to its minimum because when I look through the lens all I see is a tiny hole. I am very new to the camera world and have no doubt this is an easy fix but I would love the help.
verygratefullfromcolorado
John V
You are correct that the switch locks the aperture. In order for your camera to function correctly in the auto-focus mode you must lock the aperture to the smallest opening (largest number such as f22). The switch has two positions. The position where the switch is lined up with the orange line is the locked position. When the lens functions properly and on the camera, the lens aperture is forced wide open by a pin on the camera body pushing a lever on the lens that opens the aperture. As part of the sequence when you push the shutter button, the camera releases its pressure on the spring-loaded lever on the lens, allowing the aperture to close to the setting that the "computer" has determined as correct. You will find this lever on the outside of the black ring that surrounds the rear lens element. With the lens removed, find the lever and make sure that with the lens set to the f22, sliding the lever counter-clockwise against the slight spring tension, the aperture opens wide and returns to f22 when released. If this is not the case, the problem is in the lens. If this works, then the problem is either in your camera body or in the alignment between the body and lens. If this does not get you on the right track, let me know what you find and we will proceed from there.
Posted on Nov 28, 2008
Mar 31, 2015 | Sigma Telephoto 105mm f/2.8 EX Macro...
May 28, 2011 | Nikon Telephoto AF Micro Nikkor 60mm...
Jun 10, 2010 | Sigma 70300mm F456 DG Macro Telephoto Zoom...
Apr 22, 2010 | Quantaray 28-200mm f/3.8-5.6 for Canon AF
Mar 12, 2010 | Nikon 600MM F4D ED-IF AF-S NIKKOR Lens
Oct 01, 2009 | Nikon D90 Digital Camera with 18-105mm...
Aug 11, 2009 | Nikon D40x Digital Camera
May 04, 2009 | Sigma Telephoto 105mm f/2.8 EX Macro...
Apr 03, 2009 | Cameras
Feb 01, 2008 | Cameras
Apr 25, 2018 | Nikon Cameras
Apr 21, 2018 | Nikon Cameras
253 people viewed this question
Ty for the help, the problem I found was a fault in the lens itself. Ive already taken it to be repaired.
