Question about Toshiba Satellite A100-S8111TD Notebook
Does my Toshiba Satellite need a good battery to run on AC ?
Even if I have it on the AC it shuts down in about five minutes. The battery will not hold a charge. I checked the out the charger and it's putting the proper voltage. Any help would be appreciated--Thanks
Is there any place on line where I can get a inexpensive battery----
the cheapest one I found was $112.00
  • 837 Answers
On rare occassions I have been able to revive a battery by putting it into the freezer overnight.
Otherwise you are stuck buying a new battery.
Have you checked ebay ?
Posted on Nov 23, 2008
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
Toshiba Satellite Automatic shutdown on startup
Try F8 upon start-up and use safe mode to boot then try a doing a system restore, it may have installed an update automatically that conflicts somehow
Apr 23, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite laptop continually shuts down. Have tried running with battery, on AC power only (no battery installed) and it continues to shut down. Help?
unfortunately is sounds like your system has been compromised by a virus; which has erased or corrupted needed system files. before you give up and reformat your system you should try the Spinrite program, written by gibson research co. you can DL it here .. http://btjunkie.org/torrent/SpinRite-6-0-Release-1/3779c30edea9218ee5596b3b8c62a0aecc56767e1047
you will need a torrent service like; utorrent, shareaza, etc
Sep 12, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Toshiba satellite lap shut down. charged and now will not turn on
Try on AC if works replace battery!!swampratt200!!AAAEEE!!!!
Jul 21, 2009 | Toshiba Satellite A60-S1561 Notebook
Toshiba Satellite a205 Battery Will Not Charge
You did what all should not have been done. your battery works as a buffer between high surge of electricity which comes through electrical supply i.e. it protects your smps from burning up. From your current position it seems your smps fuse has blown. If they have given one or else your smps itself has gone. I'll tell you for your future usage of battery. Whenever you get any electronic equipment with chargable battery you should never switch it on unless and untill you have charged it for continuous 24 hours. Never try to run such equipment directly through dc or ac power. Hope your fuse has gone its not costly.
Jun 19, 2009 | Toshiba Satellite A205-S4607 Notebook PC
Blinking AC light with/without battery, computer shuts down
I want to try a very simple thing, cause it happened to me, while I am working on my computer , it shut down unexpectedly... cause the processor is working with its full performance and no enough cooling around the laptop. so while I move to other place and also I raise the laptop a little bit from the back to let the fans (bottom of the laptop) works perfectly .
try to open it again and do so.... may be it is a so simple thing that was far from your mind like I was before... good luck
Nov 29, 2008 | Toshiba Satellite A135-S4527 Notebook
Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
AC adapter cut out ? Home docking station
I have this problem too with my TAO xm2go, and that company is no longer around. But, after searching, I found there is no solution for this problem. Sorry!
Jan 18, 2008 | Pioneer AirWave XM2Go Satellite Radio...
Laptop does not power on
Somtime low cmos battery could cause the pc not to start.
Take battery out /plug in your ac adapter
Shut down computer
hit f2, this will reset the bios.
Good Luck, Merry Christmas.
Dec 05, 2007 | Toshiba Satellite A135-S2246 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
