Question about Frigidaire GLWS1339CS Top Load Washer
Frigidaire GLWS1349AS1 leaks when agitating
My washer leaks when it starts agitating. I have watched it, and you can see a puddle of water forming from under the left side of the washer just after the agitation starts.
  • jdiaz8 Jan 17, 2009
  • raboine09 Feb 07, 2009
    itl leaks out the back above the seal i also put in slow and gentle cycle it did slow the leak down
fanny
  • 146 Answers
SOURCE: Shoestrings wrapped under agitator
You will have to remove the agitator. Remove the softener dispenser from the top of the agitator and when you look down the agitator, you will see a 10mm stainless steel bolt. You will need to remove this bolt to remove the agitator. If there is no bolt, try pulling the agitator up and out.
Posted on Nov 03, 2007
the dr
  • 447 Answers
SOURCE: Agitator
Your problem is the agitator coupling is stripped. Very common on your washer. Just pull up from the base of the agitator to release it. Lip your fingers under the bottom and work it from side to side while pulling up. The coupling is the brown plastic piece attached to the transmission shaft. Remove the bolt and oring. If that bolt is rusty or oring damaged get a new one with the new coupling. Sometimes the coupler is real stuck on the shaft. Becareful not to damage the transmission shaft or the threads for the bolt to hold the coupler if you use a gear puller.
Posted on Nov 24, 2007
docjohn174
  • 943 Answers
SOURCE: Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Posted on Oct 01, 2008
  • 958 Answers
SOURCE: remove agitator on a whirlpool ultimate care II washer
have you look at the center of the agitator? after you remove the dispenser.
there i s a bolt there that you have to remove before pulling the agitator at the top.
tnx 4 using fixya,
drcool
Posted on Oct 25, 2008
SOURCE: clothes stuck under the agitator
The clothes do not go under the plate they spin out of the top and fall over the side, this is because socks and underwear are either overloaded or spun out, this can be solved by reducing the load size and also spinning small clothing items on lower speeds, but the solution above is very helpful for getting the clothes out, but you will need a long pair of needle nose pliars to pull the clother out of the bottom of the tub. This problem presented itself by a "LD" error (long drain) Thanks tzweeb and I hope this helps others
Posted on Jan 09, 2009
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Not getting any water?
very strange problem.. there is a unit within the washer that does not allow it to start agitating untill the water is at the level desired. its very clever name is water level indicator valve the valve must be jammed closed there fore the washer thinks the barrel is full of water and goes strait into wash cycle. i would say replace the w/l/i and youl be fine
good luck
Jul 12, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
I have a 7 year old Frigidaire washer (Model #GLWS1349AS1) and the water drains really slow and the spin starts before all the water is drained and then the washer leaks as water is still in it during spin...
you have a restriction in the drain somewhere or there is something inside the pump housing,chk every line from the tub to pump to drain pipe and hoses for blocks or kinks
Apr 09, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Wahser does not stop filling water
replace the water inlet valve
May 03, 2009 | Washing Machines
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Frigidaire GLWS1339CS Top Load Washer Logo
218 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
