Philips 32PF5321D/37B Powers off and on Intermitently
Recently our LCD Flat Panel started cycling the power on and off on its own. When the set is first turned on, it takes longer for this problem to occur... roughly 20-30 min. But once it turns itself off and then back on, it will continue in 2-3 min. intervals. Eventually it cycles off, the green ''power LED'' on the front still shows like the set is on, it recieves signals from the remote because it blinks every time you hit a button yet nothing happens. You have to unplug the TV from the AC Outlet and plug it back in to reset it. The twist is, if you listen to the digital music channels from the service provider, and there is no picture, the TV set performs like it should. I don't know if this is temp. related, and when the picture is being displayed its working harder and heating the components causing something to open. I've got about 6 years exp. with electronics but absolutely zero exp. with TV's. Has anyone seen this problem, or know anything about it. I've been told it is chronic with these Philips models. I thought I had escaped the disease until now. I'm sure other people have encountered this problem. I'd like to know what it was and approx. what it would cost to fix it. Thanks
    Top Expert:
  • Televison & ... Master
  • 75,017 Answers
Main power supply regulator board fault. Check and replace it. If you wish to get more details visit the site linked here.
Posted on Mar 03, 2017
  • 432 Answers
SOURCE: Blinking Red Power Light
It sounds like the horizontal (H stop) and vertical (V stop) has gone bad. Check Cap 515 and 516. IC1509, Q1505 and the jungle IC, IC206. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC.
Posted on Jul 07, 2007
  • 1694 Answers
SOURCE: TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
Posted on Nov 23, 2007
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Posted on Nov 24, 2007
  • 53 Answers
SOURCE: No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Posted on Mar 14, 2008
  • 2071 Answers
SOURCE: Hitachi 42hds69 blinks 8 times and powers off and powers on, cycle repeats
All system, geometry and white balance alignments are performed in production service mode. Before
starting the production mode alignments, make sure that all manual adjustments are done correctly. To
start production mode alignments enter the MENU by pressing “M” button and then press the digits 4, 7,
2 and 5 respectively. The following menu appears on the screen
There are 3 submenu in service menu. These are display, calibration and deinterlacer menus. Press
“◄/►” buttons to select a menu title and then “▲/▼” buttons to select a menu item and “◄/►” or “OK
buttons to set the menu item to the desired option. To exit the service menu press “M” button.
Entire service menu parameters of Plasma TV are listed below.
13.1. display menu
By pressing “◄/►” buttons select the first icon. display menu appears on the screen
blank color
By pressing /. button, select blank color. Press ./. button to set the blank color. The options are:
black, red, green and blue.
Displays panel resolution
power on time
Displays total working time of the set
backlight on time
Displays total backlight on time of the set.
calibration menu
By pressing “◄/►” buttons select the second icon. calibration menu appears on the screen.
color temp
By pressing /. button, select color temp. Press ./. button to set the color temperature. The
options are: 5500K, 6500K, 7500K, 9300K and user.
user color temp
factory reset
By pressing /. button, select factory reset. Press “OK” button to return to the factory setting values.
Posted on Jul 31, 2008
Philips 40" LCD No video
probably,did you have a look for bad caps?
make sure all the cables are housed correctly ect
Mar 16, 2013 | Philips 40PFL5505DF7 40 in LCD TV
The tv keeps turning off by istself
You may want to try upgrading the firmware. My Philips plasma set did the same thing and a firmware upgrade fixed it. The procedure is simple enough, just copy some files onto a USB drive and let the TV update itself. The release notes give detailed instructions. I couldn't find your exact model number on the Philips site, you'll want to get the correct firmware for your set.
Aug 27, 2009 | Philips 32PF5531D 32 in. LCD Television
Philips 42PF7220A/37B won't turn on at all. No green or red lights come on. This happened after we had a storm and the electric just went out. Any ideas?
Most likely it's a power supply board related issue. It maybe something simple like a blown fuse on the board. The fuse replaceable. Radio Shack or Electronic supply place will carry replacement fuses.
The other possibility is the power supply board itself is damaged. It maybe a bad capacitor or a transformer on the board. Replacement boards can be found on the internet. A good place the start is
Aug 02, 2009 | Philips Televison & Video
HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Broken LC screen
A repair will cost about $200-300 depending upon the shop. Anew one like it on sale......about 5 times that.
Apr 06, 2009 | Philips 32PF5321D 32 in. LCD Television
USB port for video?
No. Usb can only be used for photos, mp3's and slideshows. Sorry
Mar 11, 2009 | Philips 32PF5321D 32 in. LCD Television
32 Philips hd flat screen #32pf7320a/37b on for a time,then black
check the capacitors in the power supply that is the first thing to do, just check if anyone is swallen or pregnant jajajaja that's how some people call it
Dec 15, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Power cycles on/off without actually booting or starting
Unplug/replug try again. If fails, see if you are still under warranty with Philips.
Jun 17, 2008 | Philips DVDR3455H/37B
How to covert from Commercial model 20FT3010/37B
There probably is no seperate tuner module in the set as most sets now have just one board.
Mar 07, 2007 | Philips 20PF7835 20 in. LCD Television
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
