Question about Kenmore 63942 Dryer
RE: Dryer takes more time to dry clothes
  • 706 Answers
Hello mehta1007,
If your dryer is taking more time than normal, you may have one of a few problems with it.. The most obvious place to check is the exhaust duct system. Many times when the dryer is trying to move moist air out of the dryer and if the exhaust system is restricting air movement, the dry time will be extended. So that would be the first place I would look.. Check the exhaust end baffle too ( outside ).
Please let me know if that was your problem and other details if it was not..
Good Luck..
Regards,
Rick
Posted on Nov 24, 2008
Takes turning on the drying cycle several times in order for the clothes to be dry.Is there a “best” setting to use?
A clothes dryer is as simple as heat and airflow just like a hair dryer. If you have heat then you are probably lacking airflow. Check that the vent is not crushed or pinched behind the dryer and also make sure the main line is not full of lint or anything else that could be blocking airflow. If this is beyond your skill, strength, or aggravation level then you can call a dryer vent cleaning company. Timed dry cycle is the old reliable setting and clothes should be dry between 30 and 50 minutes. The "best" cycle on a dryer is one that utilizes a moisture sensor bar and thermister to determine drying time without over drying the clothes. This will be found on cycles other than timed dry if your dryer has that feature. Always pay attention to the care labels on your clothing as they will tell you how to care for your clothing such as "tumble dry low temperature".
Feb 21, 2018 | Dryers
Why do clothes take a long time to dry even if dryer is heating?
One basic reason is your washer could NOT be spinning most of the water out, therefore your clothes are wetter than they should be, thus taking longer to dry:-)
Jan 22, 2015 | Whirlpool Dryers
What is automatic dry miser
What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
GENE
Aug 18, 2011 | Whirlpool GGW9868K Gas Dryer
Takes forever for the clothes to get dry. It use to take a little more than an hour for my clothes to dry but now it takes three hours or more even with a very small amont of clothes in it!
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
May 03, 2011 | Fisher and Paykel Dryers
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
Dryer is hot, but not drying clothes. taking a
You have a plugged or resrticted exhaust flow. Remove the dryer and clean out the vent hose from the dryer all the way out of the house.
Jun 30, 2009 | Whirlpool Dryers
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Kenmore 63942 Dryer Logo
71 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
