Question about Soleus Mini Split 12000 BTU A/C Air Conditioner
Replacing squirrel cage blower
Due to our location, Soleus will not honor warranty on my split system a/c, KFR-1200. They have sent me a replacement squirrel cage for the air handler. (Original cage was damaged by loose piece of metal.) Can anyone advise me how to get the squirrel cage out and the new one in? Thanks.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 502 Answers
You have to take blower out by removing the 2 screws that is holding it ,then you loose the motor shaft from wheel by using a Allen key .Once motor shaft is loose you then loosen motor frame from housing and slide motor out .Might have to spray it with wd 40 .
On the housing should be some screws along the side so you loosen those and house ing would open up so you can get wheel out.
To install you reverse the process.
Please note the direction of the old wheel because if install backwards will not work right
Posted on Feb 14, 2018
5 Suggested Answers
  • 9 Answers
SOURCE: soleus kfr 18gwda
The fan blade can be purchased by calling 1-888-8soleus.
Posted on Mar 12, 2009
  • 9 Answers
SOURCE: Soleus KFR-18 Air Conditioner Problem
All of the kfr series have a indoor coil sensor that monitors the tube temperature. In the heating mode it will sense for high temp and cut off the outdoor fan to try to lower the indoor coil temp. The cut off temp is 129f, when the coil cools down the fan will cut in and start developing heat again. If the coil continues to get warmer it will shut off completely. The system is either overcharged or the coils and or filters are dirty. All Soleus units need both lines insulated seperately and not together because the metering device is in the outdoor unit. Have your tech calibrate the charge and make sure you clean your filters every 3 months. Removing the sensor will cause the indoor coil to get too hot and possibley start to melt your housing. For further technical questions pleas call 626-378-1518 for technical questions,,professionals only.
Phil
Soleus Tech Support
Posted on Mar 13, 2009
woobie dog
  • 1273 Answers
SOURCE: the squirrel cage in my A/C unit is noisey
Not a problem. Disconnect the lecjucity (electricity) and replace in kind.
Posted on Jul 25, 2009
  • 449 Answers
SOURCE: my Soleus KFR-18GW Split
Check your thermostsat see if there is a fan switch on it set it to auto
Posted on Aug 19, 2010
This blower motor lost some blades some how threw it all out of wack (wobbly) so much it hitting casing. Motor works. Would I need to replace everything or just the blade wheel ? It is an older amana air...
you may have to replace the blower because the squirrel cage is out of balance due to the loss of blades.
and may have damaged the bearings/bushings
if you can get just the squirrel cage that great
Sep 13, 2013 | Heating & Cooling
How to replace blower wheel on Friedrich SL28M30 AC unit
follow this steps and fix it. God bless you
    • 1
      Turn the electricity to the air conditioning unit off at the
      service disconnect box. Follow the wires from the AC unit to the
      disconnect box, usually located next to the unit. Open the disconnect
      box and, depending on the type, either pull the buss-bar or flip the
      disconnect switch.
    • 2
      Open the air handler\'s access panels with the correct size of nut driver, usually 5/16- or 1/4-inch. Save the screws.
    • Remove the control panel\'s cover, if equipped, with a nut
      driver. Some models have a flat metal cover over the electronic
      controls, and some control panels butt up to the unit\'s access cover.
      Save the screws and access cover.
    • 4
      Follow the wires from the blower motor. Two wires will go to
      a capacitor located on the blower\'s housing. The rest of the wires will
      go to the control panel.
    • 5
      Cut the wires leading into the control panel with wire cutters. Leave the cut wires connected inside of the control panel.
    • 6
      Remove the retaining bolts with either a nut driver, usually
      3/8-inch, or an adjustable wrench. The retaining bolts, found on the
      mounting brackets that the blower\'s housing slides on, keep the blower\'s
      housing locked into position. Save the bolts.
    • 7
      Slide the blower motor\'s housing out of the AC unit. The housing will slide straight out along the mounting brackets.
    • 8
      Disconnect the two wires going to the capacitor. They will pull straight off the capacitor\'s terminals.
    • 9
      Unscrew the squirrel cage\'s locking-screw with an adjustable
      wrench. The squirrel cage, the bladed wheel, connects to the blower
      motor\'s shaft inside of the housing. The locking screw holds the
      squirrel cage to the shaft.
    • 10
      Unscrew the blower motor\'s mounting screws with either a nut
      driver, usually 3/8-inch, or an adjustable wrench. These screws hold
      the motor to the housing and are found on the opposite side of the
      squirrel cage, the same side that the wires leave the motor.
    • 11
      Pull the motor from the housing. A drop of oil on the shaft
      will aid in removal. If the squirrel cage sticks to the shaft, then hold
      the shaft still with an adjustable wrench while spinning the squirrel
      cage on the shaft.
    • 12
      Slide the new blower motor into the housing. The blower motor\'s shaft will slide into the squirrel cage\'s hole.
    • 13
      Tighten the blower motor\'s mounting screws.
    • 14
      Spin the blower motor\'s shaft until the flat part of the
      shaft lines up with the squirrel cage\'s locking screw. Move the squirrel
      cage in or out until it does not touch the housing or the blower motor.
      Tighten the locking screw.
    • 15
      Connect the blower motor\'s capacitor wires, usually brown or
      brown with white stripes, to the capacitor. Direct replacement motors
      use the same color-coded wires as the original.
    • 16
      Slide the blower motor\'s housing into the AC unit along the mounting brackets. Install the mounting bracket\'s retaining bolts.
    • 17
      Connect the new blower motor\'s wires in the control panel
      one at a time. Disconnect one old wire in the control panel. Determine
      its color and connect the new wire, of the same color, to its place. Do
      this for all wires.
    • 18
      Replace the control panel\'s cover, if equipped, and the
      unit\'s access cover. Turn on the power to the unit at the disconnect box
      and test the blower motor.
Jul 17, 2013 | Friedrich Kuhl Series SL28M30 230 Volt,...
Hi, my 1998 dodge durango front AC/Heater blower motor run on and off, after the fan shuts down and stops running if I reah under the dash and hit the plastic fan housing it will start-up running but it...
If you can hit on the blower motor housing and the motor starts, your brushes on the motor are bad and the blower motor needs to be replaced. Used tested unit $30.00 at a junkyard. New rebuild $54.00.
Many posts have stated that the dash must be removed to replace the blower motor. It can be done without removing the dash. I know as I replaced the blower motor on my kids 99 Durango last night but it took about 4 hours. Now that I know how to do it, it would estimate 2 hours.
Remove glove box by opening glove box all the way. Press inward on the both sides of the glove box to allow the rubber stops to clear the catches and lower the box The two outer hinges (plastic) will come off by slightly twisting the glove box upward leaving only the center hinge (plastic) in place. Reach in and push down on the hinge to pull out glove box. Set aside.
Remove side trim panel by pulling back carpet and remove one Phillips screw. Remove panel by pulling back on upper portion to remove clip from frame, then slide forward to remove from lower plastic trim.
Use 1/4" nut driver or socket to remove two screws holding vacuum canister on lower right side of blower shroud. Remove two vacuum hoses noting which hose goes to which side of the vacuum canister (both were green in color on my Durango). Disconnect connecting rod from vacuum canister to vent control by removing lock washer (you may be able to get away with not removing the rod, but the plastic "fin" may break if you stress it while removing the blower shroud.
Use 5/16 nut drivers/sockets with extensions to remove the blower shroud hex bolts. The hex bolts are located in several areas around the shroud (use your finger to follow shroud edges to locate all 8). Some of the hex bolts are very tricky and may require odd positioning of your body to locate and remove them.. I also put several extensions to use in order to reach the various hex bolts. Once the hex bolts are removed, pull the plastic blower shroud down exposing the blower motor squirrel cage.
Remove two of three hex nuts holding blower motor in place. Loosen the third one and the blower motor should come free. I was not able to remove the squirrel cage from the old motor so I broke the squirrel cage allowing me to expose the wire harness and grommet that went through the back of the shroud.
Feeding the wire harness back through the assembled wall appeared to be a real challenge, so I cut the green and black wires at the motor for splicing into the new motor later. Remove the motor and broken squirrel cage and throw the dam thing away.
Remove squirrel cage from new motor by removing retention clip with a pliers. Pull off the squirrel cage carefully by applying WD40 (or other lubricant) to the shaft. You may have to place two large screw drivers or other pry bars underneath the squirrel cage equally across the underside of the squirrel cage slowly prying up the cage. I accomplished this with a helper to hold the motor in place to allow equal pressure from both pry bars.
Cut green and black wires on new motor leaving enough wire to work in the tight area of the motor housing. Strip wires from old harness and new motor and apply **** splices for green to green and black to black. Add electrical tape for extra mechanical strength and insulation.
Place new motor into housing and secure the three mounting hex nuts. Turn on key and run blower to make sure it works. Install squirrel cage and retaining clip on motor shaft. Run again to make sure it works.
Install the balance of the items in the reverse order you removed them.
Now on to replace the rear wiper motor on the same Durango. Junkyard parts $54.00. Time: Unknown?
Jul 31, 2011 | 1999 Dodge Durango
Replaced the blower motor wheel.. its a flap that turns that makes noise..don't no the name
Hello: To replace the "squirrel cage" you have to replace the complete blower motor.
Jan 13, 2011 | 1995 Chevrolet C1500
My unit turns on and blows for a minute, then stops blowing.
you need to call a service man. Your transformer, blower motor or wiring is probably melting.
Aug 11, 2009 | Soleus KFR-18GW Split System Air...
The squirrel cage in my A/C unit is noisey
Jul 25, 2009 | Soleus Mini Split 12000 BTU A/C Air...
Soleus kfr 18gwda
Mar 11, 2008 | Soleus KFR-18 Air Conditioner
Heating & Cooling Logo
577 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
