Cars & Trucks Logo
Posted on Jun 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toyota Echo gauge cluster lights wont turn on?
The gauge cluster lights do not light up. I checked the fuse and it is good. I pulled out the cluster and checked the bulbs they are good. I also pulled out the dimmer switch and hooked my multimeter to it and it has 12v on one end and gradually goes down as I turn the knob down to .033v so I assume that is working properly. If the cluster is bad how can I repair it? If its just somewhere I could re-solder a point to get it working again that would be cool!
Richard Faber
Level 3:
  • Cars & Trucks Master 1,444 Answers
  • Posted on Jun 17, 2017
Richard Faber
Level 3:
Answers
1444
Questions
Helped
380194
Points
5288
Check for voltage where the wire from the switch connection to the cluster if you have voltage then something is wrong with the cluster
4 Related Answers
Anonymous
  • Posted on Feb 10, 2009
SOURCE: gauge lights not working.
Solved the problem -on of the fuses in the relay box under the hood was bad - Although it is not marked well - It says park and horn????
Anonymous
  • 123 Answers
  • Posted on Mar 09, 2010
SOURCE: cluster and dash lights not working
YES
jturcotte
Jeffrey Turcotte
  • 8991 Answers
  • Posted on Nov 28, 2010
SOURCE: gauge cluster lights won;t light
When you put the stereo in, what did you do with the red wire with a green stripe? The aftermarket radios don't always use these, so you have to wrap the ends, depending on whether or not you used a wiring harness. If that wire is shorted on the chassis, it will blow the dimmer fuse.
1995 Honda Accord Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/White
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: Yellow/White
Car Stereo Amp Trigger Wire: Violet/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 6 1/2?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
cansmo
Reynaldo Andico
  • 2431 Answers
  • Posted on Mar 08, 2012
SOURCE: dashlights and high beams wont come on
Play with the ignition switch,If you can disable the starter when the engine is running and can do it in a very safe manner,this way you can turn the ignition and check to see if a ignition electrical part is failing, If you cant disable the starter just be careful how you turn the ignition you are only ruling out the ignition switch electrical part as possible problem or even the solution
2003 Toyota Echo. Why aren't instrument cluster lights working?
Double check fuses 8 and 11.
Toyota Echo (2003 - 2005) - fuse box diagram - Auto Genius
https://www.autogenius.info > toyota-echo-2003-2005-...
Aug 7, 2016 - Toyota Echo (2003 - 2005) - fuse box diagram · Engine room J/B · Instrument panel J/B · Fuse box · Fuses (type A) · Fuses (type B) · Fuses (type C) ...
Toyota Echo 2003 gauges service light not working
the bulb might be out on the service light in which case you will have to remove the cluster and replace the blub. a/c you will have to go to a shop to get looked at. most likely you have a leak somewhere in the system
2002 Toyota Camry Stalls when accelerator pedal is released
You lost the idle leaning, so just drive it until the idle relearns.
1helpful
2answers
Which fuse runs the lights on the dashboard? fuel gauge and speedometer don't light up!
This is the PARK LAMP fuse . So check this out on the under side of the dash and use a nose plier to pull the fuse out to be replaced by the spare in the box.
If the fuse seems ok, then check the harness, connectors to the dashboard cluster or the lamps within the dash.
1helpful
I have a 1991 chrysler new yorker, and the instument cluster just went out. all the turn lights work and check engine dummy light work, just no speed and gas gauge. checked all light bulbs, and fuses with...
okay if the light work then it wont be a fuse, this sounds like a bad connection or bad cluster. remove the cluster and unplug the connectors to it and then reconnect them and start the car and see if they work if not then i would say the cluster went bad, good day.
Have a 98 GMC sonoma and was driving down the road yesterday when all of a sudden all dash lights went out. Checked all the fuses and they were all good. Radio lights go out to, but when i turn the key...
This can be a poor connection at the back of the cluster, pull it out and check all the connection points to make sure they are fully seated to the cluster.
1helpful
2001 grand caravan no gas gauge heat gauge no odometer rpm lights
check for an instrument cluster fuse in the fuse panel if it's good you will have to pull the cluster out and change the lights behind the gauges
1helpful
Feul temp oil pressure gauge not working
this problem sounds like a bad ground to your gauges first check your fuses with a test light take the end of light ground on battery with a long wire with alligator clip on end so you can reach around to test second thing take probe tip touch pos of battery to make sure tester lights then test all fuses first both sides most fuses have two little holes one on each side on top to put probe on fuses should light up on both sides some fuses wont light on both unless the ignition is turned to acce or for instant a headlight switch has to be on to test fuse if fuses check out okay you will have to get into the gauge instrument cluster possible if these gauges are pushed into a pin type or flat circuit board its possible loose scews and a good bump would make a bad contact in the cluster
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
