Question about Onkyo TX-SR702 Receiver
Switched outlets on Onkyo 702 are always on.
My outlets are on when the unit is in standby. Is there a way to change this? They are labeled as "SWITCHED".
Zone 2 has to be turned OFF for the switched outlets to turn off in stanby mode.
Posted on Nov 24, 2008
How do I disabled the standby on my onkyo av receiver TX-SR607
Hi Ms Cazarez, all of our receiver go to standby when powered off as such there is not way to disable the feature unless you just unplug the unit form the AC outlet, Thanks, JT
Mar 14, 2015 | Onkyo Audio Players & Recorders
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
Bought a used Martin Logan Dynamo subwoofer a couple days ago and have a very loud hum when the ac cord is plugged in, even if the speaker is not connected to an audio source. The "hum" can be heard in any...
Neither the amp or the sub have grounded power cords.
I have discovered the ML Dynamo takes about 30 minutes to switch to standby in auto mode.
With speaker level inputs connected to the Onkyo A807 amp, both units powered from the same wall outlet, Dynamo sub on Auto, the sub hums for about half an hour after the Onkyo is switched off, then the sub goes quiet. Not so good.
I connected a bonding wire between the two units on 3_7_09. If I smoked some old audio gear I could just look at that as an opportunity, right?
Works fine. Now I have the ML powered from the wall and working normally.
Jun 30, 2009 | Dynamo MartinLogan Subwoofer Speaker
Standby light remains on for Harman Kardon 5 disc CD player
Modern electronics stay in standby mode when you turn them off because certain circuitry must remain powered up to be alert for remote control signals. In essence its always awake looking for the remote to send a signal at which time it will turn on the rest of the circutry and fully power up the unit. It is not a fire hazard and the LED's used now days have lifetimes of several thousand hours. You can plug it into the switched outlet on your reciever if you wanted to. However be sure that you do not exceed the rated wattage for the switched outlets. You can determine this by figuring out the rated wattage for the outlet(s) as it will show this rating near them and it will show the wattage required by your cd player on the back of the unit somewhere near the power cord.
Jun 06, 2009 | Harman Kardon FL8385 5-Disc CD Changer
I have an Onkyo TX-8511 Receiver. The unit has power because the standby light is on, but nothing happens when I press the power button or try and turn it own with the remote. I have Onkyo HTS907 that...
You have two devices that won't power on. Doesn't that suggest a source power problem? Did they ever or never work where you are now or anywhere else? Or did you just come back from overseas and forget to set them up for U.S. power?
And you're not daisy-chaining the two units together, are you? That's a no-no. There's a wattage limit to what can be connected to the convenience outlets. Power amps are not usually supported.
Try isolating the two units and shoot each bug separately. Plug them in somewhere else. Disconnect speakers and try again.
C'mon back with the results.
May 08, 2009 | Audio Players & Recorders
Onkyo TX-DX838
I went back and found a loose cable/coax. Re-attached and now the receiver works as good as ever.
Sep 02, 2008 | Onkyo TX-DS838 Receiver
Onkyo TX-8522 stuck on standby
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Nov 15, 2007 | Onkyo TX-8522 Receiver
Brand new Onkyo Tx-sr605 won't leave stand by
If the unit will not leave standby I would remove all power, disconnect *all* connections at the back, reconnect to a power source and try powering on. This will eliminate any connection causing the Onkyo to stay in standby due to a short. If it still will not enter power-on mode, you may want to look at the power source (is it properly grounded?), but beyond that the unit probably needs to go back.
Nov 03, 2007 | Onkyo TX-SR605 Receiver
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Onkyo TX-SR702 Receiver Logo
255 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
