I am wondering what and how much it is gonna cost when the miles are as high as 100000. is it worth paying for this type of car?
I would stay away from any car no matter the manufacturer with this many miles on it, it may run great but many other parts like the front end and steering are at the end of there life span, trust me on this. If i was to choose a car to buy with high miles like this I would buy a Honda or Toyota. This car is EXTRMELY EXPENSIVE TO HAVE REPAIRED!
SOURCE: jump start an 1991 audi
connect a 30 amp wire to the starter terminal on the ignition switch and put a switch in the dash with a live to it. to start the car put the ignition on and put the switch on, the car should start
SOURCE: 2001 audi a6 quatro, electrical fire, should audi have to cover $
KEEP BACK FROM DEALERSHIPS!!!!! WILL RIP YOU OFF BIG TIME.....ALWAYS GET A LOCAL GARAGE TO DO THE WORK(ALWAYS ALOT CHEAPER AND BETTER) SHOULD HAVE GOT A ROUGH PRICE FROM YOUR LOCAL GARAGE FRIST........
SOURCE: Oil questions for 2003 Audi A6 Quattro
oil type is either 5W-30W or 10W-30W depending how cold your climate is, as far as having the car properly taken care of, the Audi dealer is the best option, they have all the proper tools and service info needed to keep the car in top running condition.
SOURCE: Timing belt replacement for a 1999 Audi A4(elective)
Well, the labor on this specific Audi will be 5.5 hrs+ parts. the labor depends on the shop. every shop is different. lets say you brought it to my shop.my labor charge is 50 dollars an hour so, that will be a $275.00 labor charge added to the part cost which would be $220.44 for the timing belt and tensioner combined. this brings you to a total of $495.44 for the total repair. Keep in mind, this figure was calculated on the basis of a 50 dollar an hour labor charge. it can flucuate ethier way, depending on what shop you take this vihical to. I must say that, its better to replace it before it breaks and, it is a good rule of thumb to replace the water pump as well at the same time as this repair.
Please rate and have a great day:)
SOURCE: what cost to buy and put on 4 brake rotors please on audi A4 1996
Rotors cost around 40 each labor should run around 80. depending on who does it total around 240. just a estimate all shops vary .. this does not include pads .. Thanks Jerry
