Question about Sharp XLDV50--100 Watt 5-Disc Table Top System with DVD/CD Multi-Play Changer in Silver Shelf System
Remote Buttons Don't Work
Some of my number buttons and the 'up' 'down' arrow buttons dont work. This is bothering my because i can't get through the menu well. anybody know a fix?
0 characters
1 Points
Buttons on the stereo, sony zx66i, will not work but the buttons on the remote do. Unfortunately, there is no botton to open the 5 disc changer. Is there a reset button or way to fix it?
check all the buttons and make sure one is not stuck in. If there is one stuck button, it could cause all the others to not work. If you find a stuck one, it will usually pop back out with a little help from a small screwdriver
Apr 09, 2014 | Sony LBT-ZX66i Shelf System
Sony lbt-g1300
Check that none of the buttons are stuck in. If one of the buttons is being pressed, none of the other buttons can function.
May 20, 2013 | Audio Shelf Systems
Connect a good FM antenna to the unit's antenna jack to make sure you get good radio reception. Power on the unit. Press the Tuner/Band button. Adjust volume and tune to a known station using the up or down arrow buttons..
Mar 05, 2011 | Sharp CD-MPX850 Shelf System
CS-325 CD/Receiver is not advancing am or fm station frequencies
Performed the hard reset by turning on the unit prerssing the button with a square symbol and power at the same time. To tune on face must depress the arrow buttons firmly and hold for a bout 1.5 seconds, then tuning begins.
Mar 26, 2009 | Onkyo CS-325 Shelf System
HOw do you set the clock on an RCA RP9328A stereo without remote?
I have this system. According to the manual you have to do the following. 1. Press and hold the TIMER/CLOCK button until CLOCK appears in the display under the time. 2. Press the SET button once and the hour will flash. 3. Use the << or >> buttons to ascend or descend to the correct hour. 4. Press the SET button again and the minutes will flash. 5. Use the << or >> buttons to ascend or descend tot he correct minutes. The time will flash for a few seconds and be set when it stops. I have tried those steps and you may have to do them a few times in order to get the time right. It's a little tricky. I haven't bothered to reset the time as I have other devices that display the time without the back and forth with this device. It's a nice system and the sound is okay for my purposes. Hope this helps.
Mar 14, 2009 | RCA Audio Shelf Systems
Clock Reset
Hold the memory button in which is located on the top of the unit until the clock digits flash. Set the hours by holding the up or down arrows on the skip buttons which are again located on the top of the unit until you get the correct hour. Then press the momory button once more for the minutes and set these again using the skip up and down buttons. When time correct press the memory button again to set.
Mar 13, 2009 | Audio Shelf Systems
Griffin evolve remote not functioning
how did you take off the back to put in new batteries... try syncing your speakers by holding the 2 volume buttons on the base at the same time for about 2 secs.... the light will start to blink and you just click any button on your remote. If that doesnt work then its firmware
Dec 28, 2008 | Griffin Technology Evolve Wireless Sound...
Unresponsive buttons
First, try unplugging the unit for a couple of hours. That should reset the internal microprocessor. If that fails, try pushing all of the buttons one at a time. If one of them is stuck, nothing will work properly. You should be able to feel the button working. Report back here with your results.
Mar 12, 2008 | Sharp XL-MP130 CD Shelf System
Unable to set clock
hit shift and clock (9) on your remote.
use the left double arrow and right double arrow buttons on the bottom to change the time...note: once you hit the shift and clock buttons, you have only 4 seconds to press another button...
once you have the time set, you can hit the pause button on the lower section to finish.
Dec 04, 2007 | Aiwa NSX-AJ200 Shelf System
Sharp XLDV50--100 Watt 5-Disc Table Top System with DVD/CD Multi-Play Changer in Silver Shelf System Logo
Top Sharp Audio Shelf Systems Experts
Are you a Sharp Audio Shelf System Expert? Answer questions, earn points and help others
