Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Cannot adjust convergence, screen has rainbow effect
My Panasonic PT-47WXC43G has a rainbow effect across the whole screen, and adjusting the convergence doesnt seem to help. When watching cable tv, the problem is not so noticable, but when I turn on my video games, you can clearly see all three colors, in a ghost-like effect. Is this a bad bulb, or something else?
  • 3 more comments
  • Federico Rivera Apr 08, 2008
    I own a PT-51G and blue is coming off convergence past the point that it would be adjusted with the remote's convergence in setup.
    I have adjusted this before using a procedure obtained from a Panasonic service center.
    The screens I entered showed a sequence of grids for each color and each section of the grid could be adjusted up/down & left/right for each square on the grid individually.
    Unfortunately I lost the procedure ! - Could any one out there send me the keys sequence to enter those screens. I have service manuals with me but they don't show that in there, only the list of parameters for each mode.
    Thanks, F
  • Rob McCutcheon
    Rob McCutcheon May 11, 2008
    hello i have a pt-53wx53 with a convergence rainbow problem
    what va==can it be
  • Anonymous May 18, 2008
    red
  • Anonymous May 26, 2008
    I also have the same problem,took the back panel off the back of the TV.All three of the bulbs are working, cleaned off some dust and even moved the top of the bulbs it has a wingnut that you can move the top of the lens that adjusts the focus.It did not help out all,and ideas?
  • RDPLZ67 Nov 08, 2008
    CANT GET COLORS CORRECT
You probably need to change out the semiconductors. The parts are STK392-110. There are two of them, one for horizontal and one for vertical. Search it online more.
Posted on Oct 01, 2007
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
My panasonic PT-47wxc43g projection tv has developed shrinkage in the middle of the screen on both the top and bottom. The picture has an hourglass on its side appearance. The picture is now also too large...
This could be a problem in the convergence board which will cost of repair would range 400.00 or so.
You can get the convergence repair kit at the following link which contains the parts and step by step detailed instructions.
http://www.tvrepairkits.net/panasonic_repair_kits
Thanks
Kevin
Jun 29, 2009 | Televison & Video
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic 51" projection tv, green/purple rainbow across the bottom and the words at top of screen are bent up
Convergence it dead.Convergence ICS and all of it resistors must replaced to solved this problems.Know how to solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com.Shop well cost u $300 for parts and labors.
Jan 19, 2010 | Panasonic PT-51HX41 51" Rear Projection...
PT-47WXC43G green convergence no longer in alignment...
you can get the following repair kit at the following link. which contains the parts and the CD which has the instructions on how to do the repair. The kit you need is called the PT-53WX53G, PT-56WX53G, PT-
47WX53G, PT-47wx33G, PT-47WXC43G
and PT4743G. Convergence repair kit its at the following link.
http://www.tvrepairworld.com/
Jul 15, 2009 | Televison & Video
Convergence problem
The reason you can not adjust it is because there is hardware failure in the convergence board.
Visit this website and ask them for a convergence assembly for your TV. Once you replace that assembly, the convergence might still need to be adjusted manually.
Good Luck.
Apr 13, 2008 | Panasonic PT-56WX51 56" Rear Projection...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
White outlines in HD mode
is the screen control turned up to high if so you would see white lines on a dark picture
Oct 30, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic 52"problem
You need to change the two convergence IC's - Generic part# STK392-110, Panasonic part# C5AA00000203. You might have problems using the generic #, I would use the Panasonic #
Sep 26, 2007 | Toshiba 46HM95 46" HDTV
Pt-47wxs1ce green wave at bottom of screen cannot adjust green convergence
you have bad convergence IC's and possable 1 bad resistor
let me know and i will help you find them in the set if your are a good solderer - or call a tech
thanks
scott
Aug 30, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
536 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
