Question about OKIPAGE 8z Led Printer
Resetting image drum
Help!! how do I reset the drum count?
  • 114 Answers
U need to go on the program in your computer and from there reset the drum, probably u have one called okidata, ther u have a OP8z monitor.
Posted on Jan 17, 2007
SOURCE:
How can I enter the Tech Mode to reset the counters?
Imaging drum reset chip Ebay £15
http://www.ebay.co.uk/sch/i.html?_odkw=Imaging+Drum+reset+chip+for+Samsung+Xpress+SL+C410W+Xpress+SL+C460FW+SL+C460W&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XImaging+Drum+reset+chip+for+Samsung+Xpress.TRS0&_nkw=Imaging+Drum+reset+chip+for+Samsung+Xpress&_sacat=0
Mar 15, 2016 | Samsung Xpress SL-C460FW Laser...
My bizhub 250 said the drum needed to be replaced, which i did, however the printing is so light and the machine still says to replace the drum. What am I missing?
The drum counter must be reset by using the service mode. But that is not your bigger issue here. The drum section is part of the Imaging Unit. When you change the drum section you are also suppose to change the developer (starter) in the developer section. So when you reset the drum count this also "resets" the atdc (automatic toner density control) ratio which must be recalibrated using the F8 mode. The 2 are tied together. You can try doing F8 without replacing the developer but this is just asking for trouble. Just resetting the drum count will mean you have at least a 50% chance of getting a COF32 code which is an atdc sensor failure because of the ratio mis-match that will occur.
You either need to find Imaging Unit rebuilding instructions or have a service tech come out and take care of this properly.
Good Luck and Thank You for using Fixya.
Jan 24, 2011 | Konica Minolta bizhub C250 All-In-One...
I have a Sharp model AL-1642CS and the drum light is on. I replace the drum not to long ago and it worked fine.. maybe 2 weeks ago. Now the light is back on. I swapped out a drum from another working...
You press # * C * in that order. The machine will go into diagnostics. You then enter either 24 or 27, then enter 06 and 07. Those will reset drum and developer counts. Off hand I don't remember if the first number you enter is 24 or 27, but you will get a maint clear message. 06 and 07 are the second number you enter, one for drum reset one for dev reset.
Aug 03, 2010 | Sharp AR-5316 Advanced Digital Imager...
I changed the drum and there's still a message saying order drum....is there a way to reset that?
(from Okidata's support site)
After replacing the image drum cartridge, reset the drum counter to keep a correct count of the number of pages printed on the image drum.
1. Turn the printer on while holding the MENU 1/Menu 2 button. USERMNT displays in the control panel window.
2. Press MENU 1/Menu 2 three times. DRUM CNT RESET displays.
3. Press ENTER. The counter will reset and the printer will go ON-LINE.
Jun 30, 2010 | OKI Electric Industry B4600 Laser Printer
Says to change drum, changed drum and still says "change drum", will not print.....
Dec 16, 2009 | OKI Electric Industry B4600 Laser Printer
How to reset DCP 7030 drum unit
Reset DCP 7030 drum unit : -LCD-
Press MENU and turn on printer - MAINTENANCE
arrows 81 and OK -RESET DRUM COUNT
press OK -RESET LIFE COUNT
press CLEAR / BACK
arrows 99 and OK
ready
Oct 26, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother 8360p says change drum soon
You have to open the front door and then press options, should see Replace Drum? just answer yes.
Sep 09, 2009 | Brother MFC-8440 All-In-One Laser Printer
Displaying mualfunction detected (bizhub 250)
i will like to know how to reset the page count and service my konica myself, also my konica bizhub 250 is showing C-0204
Feb 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Drum Cartridge help
go to the menuel button and scrool down until you see reset count.do not silect toner reset.choose drum reset and enter and it will (0) out.
Apr 01, 2008 | Sharp AL 1631 Copier
OKIPAGE 8z Led Printer Logo
272 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
