Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whitlpool Gold Range Locked
The sensor screen has LOC on it and will not allow me to Bake or Broil or set the temperature or anything. As if the stove has froze. What do I do to Unlock this stove.
5 Suggested Answers
  • 31 Answers
SOURCE: whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl,  You do not indicate the model number or the age of the stove.  Early model self clean stoves used a 'oven lock door handle.'  Later model stoves do not use such a handle but is electronic. I believe this is the one that you own.  You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature?  If not... I believe that you have a touchpad control problem.  You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning.  If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM).  It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM.  The oven ECM is very expensive ($150-275. retail) plus labor to install.  Hopes this helps you!  HandyHenry
Posted on Feb 07, 2009
Fixe_You
  • 1800 Answers
SOURCE: Display is in LOC but door is not locked. Can't set temp. to bake
check if u can find any reset procedure.
alsio u can let it with no power for 30mi that will reset it Int.Memory.
Posted on Feb 16, 2009
  • 572 Answers
SOURCE: Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Posted on Feb 09, 2010
richroth
  • 9472 Answers
SOURCE: Oven temperature setting (on bake or broil) only
What is the model number the is posted on the range?
Posted on Feb 04, 2011
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
Top element wont heat wen oven is on bake
The top element normally operates only when you turn the temperature control all the up to the broil setting as it is the broiling element. If it doesn't work at the broil setting, suspect a bad brioler element or a faulty temperature control.
Aug 11, 2009 | Frigidaire Gallery GLEFM397DS Electric...
F2 IS FLASHING ON STOVE AND BEEPER WILL NOT STOP
F2
During
BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Apr 15, 2009 | Hotpoint RGB745 Gas Kitchen Range
Digital oven will not turn on, I press bake/broil it reads ''Loc''
Look on the control panel for an icon that looks like a padlock near one of the buttons. Hold that button down until it beeps and that should unlock the panel.
Mar 20, 2009 | Ovens
Kenmore 9114554590 will not bake or broil
The clock/display panel is faulty. There are a few relays on the display that have to work. If the clock is just flashing once with each keypress the the relays are not functioning. The clock/diplay will need to be replaced
Jun 04, 2008 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
19 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
