Question about Kenmore 13599 / 13594 / 13592 Built-in Dishwasher
Kenmore ultra quits working pf and e8 light come on
I have a kenmore ultra wash model 15925691 it quits working, sometimes you get a pf light, sometimes you get e8 light. It does not loose power and the float does not appear to stuck. Any suggestions
If your pf light comes on that means that your outdoors fuse needs to be replaced. The same thing happened to me and I bought another dishwasher for the same proble to occur. I don't know if it's to late but the only thing wrong is your fuse is blown. Good luck!!!!!
Posted on Apr 12, 2009
Kenmore ultra bake self cleaning super capacity electric oven is showing the letters pf in red what could this mean?
PF usually just refers to power failure. You should only have to reset your clock and then check to make sure everything else works.
Jun 15, 2015 | Kenmore Ovens
Kenmore ultra wash dishwasher
The only time I have run into something like this when trying to help a client, we found that there was a shut off switch up on the wall above the counter. It looks just like a light switch and sometimes someone accidently turned it off and the dishwasher no longer worked. I do not know if you might have a situation like that but maybe it might help and save you a service call.
Jul 30, 2014 | Kenmore 24" Built-In Dishwasher with Ultra...
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
PF Flashes? Any ideas?
PF simply means your Power Failed sometime since the last use.
Power off and Power on to remove the PF Code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 10, 2009 | Kenmore Elite 45986 Front Load Washer
Suddenly stopped working - won't run on any cycle.
First check the electrical supply. I have seen dozens of dishwashers which did not have the hot wire connected tightly enough (inside the connection box behind the lower panel). Sometimes the loose wire caused the breaker to blow. If you have control lights but the dishwasher will not start it could be a bad door latch saftey switch. $10 part, cheap. Hope this helps, Ken
Apr 24, 2009 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Kenmore 13599 / 13594 / 13592 Built-in Dishwasher Logo
349 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
