Question about Polaroid Televison & Video
Polaroid Portable DVD player, Cover hing spring is lost, need replacement spring and can not locate. mod# PDM-0711 Where can I get this simple little spring? Thanks Frank Di Martino
5 Suggested Answers
  • 79 Answers
SOURCE: Broken Door: Polaroid PDM-0711
You probably cant replace the door because usually they produce a small run of these players and then create a new model and discontinue the old one very quickly. My suggestion is to look if there is a small button around the area the tab would normally go to when you close the door. If you can see this button try to find someting that would keep it pressed down. This tricks the player into thinking that the door is closed. WARNING: This button also activates the laser reading unit so you must have a dvd loaded before you press the button so you dont accidently look straight into the laser unit. IF YOU LOOK INTO THE LASER YOU CAN CAUSE PERMANENT EYE DAMAGE OR EVEN BLINDNESS.
Posted on May 01, 2008
  • 79 Answers
SOURCE: Polaroid PDM-0711 DVD Player Parental Lock
Did you check the manual for a way to reset the region lock?
  • 303 Answers
SOURCE: lost power cord for Polaroid PDM-1058 portable DVD player
You can buy a new one by clicking on the hyperlink:
buy replacement ac adapter power charger cord for POLAROID PDM-1058 PDM1058
Posted on Mar 04, 2009
ejkudelka
  • 1188 Answers
SOURCE: polaroid portable DVD player error code ''bad disc''
You'd need to open the unit, and the problem is either that the laser and the tray are misaligned, which can be tricky to fix even, or worse, you need a new laser. Either way, the Polaroid dvd player may not be worth getting repaired if it is no longer under warranty.
Good luck!!
Posted on Nov 29, 2009
i have a pdm-0711 by polaroid the sound playes but no picture
Posted on Jan 15, 2010
I have a Polaroid pdm-08228bd that whenever we put
when you open the cover for the DVD you will see the laser ..its a small lens like device mounted on a spring like assembly .. you can manually clean that laser with a soft paper towell soaked in eyeglass lens cleaning solution .. dont spray the solution on the laser directly .. make sure the spindle spins freely in the center where the disk mounts ... when you close the lid and turn power on you should be able to hear the disk spin .. if you can hear it spin and hear some clicking but still wont play then you likely have a worn out laser .. unfortunately the cost of installing a new laser is often greater than the cost of a new DVD player ...
here are a few models that might be worth looking at ..
http://www.consumersearch.com/portable-dvd-players?gclid=CITHuImPjaICFchD5godvmnzUw&ef_id=1953:3:s_241d3be5bdd1ae954a703c1c03b3e8bb_3674119072:TAxys0NIYWYAAGzz04MAAATA:20100607041651
Jun 07, 2010 | Polaroid PDM-0723 Portable DVD Player
Lost remote
http://bestbuy.partsearch.com/
Mar 03, 2008 | Polaroid PDM-0742 Portable DVD Player
Dec 03, 2007 | Polaroid PDM-0711
Nov 19, 2007 | Polaroid PDM-0711
Lost power cord for Polaroid PDM-1058 portable DVD player
I've looked for the same thing and the only place I can find it is eBay for about $25
Nov 08, 2007 | Polaroid PDM-1058 Portable DVD Player
NEED REPAIRS ON DVD PLAYER
polaroid dvd pdm-0722 it playes but no picture if you push the button near the screen it will come on for a second but the picture is also upside down can you help thanks this player is not used that much no kids thanks
e-mail is corv1990@eatel.net
Sep 02, 2007 | Polaroid PDM-0824 Portable DVD Player
Televison & Video Logo
43 people viewed this question
Top Polaroid Televison & Video Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
