Question about Ovens
Halogen ring not working
I have a belling halogen cooker model 631wh the halogen ring will not work when i turn the knob to turn it on nothing happens but when i turn on the other kobs to turn on the other rings you can hear a little click noise for it to come on but when i turn the halogen knob you cant hear enything ? doyou think the switch as gone or is it the hallogen ring ?
  • Ovens Master
  • 3,463 Answers
Hi .
It sounds like the temp control is faulty.
Either way you are going to have to remove the hob top to access the controls and elements, Then you can check if the element is getting a feed to it.
Sometimes you can see if the element has gone, .
If you need any further help, let me know.Good luck.
Posted on Nov 23, 2008
How do I change the fuse on my Belling solid ring cooker?
If 2 rings are not working, then it is probably the rings that are faulty
It means testing the rings with a meter.
Feb 25, 2015 | Belling Ovens
Hotpoint ew91 halogen hob wont turn off
the control may have shorted. replace control(behind the knob).
Sep 10, 2012 | Hotpoint Ovens
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
Hi, I have a Belling gas cooker, the oven and grill are working fine but there is no gas coming through the rings at all. Could someone tell me what the problem could be and would it be expensive to fix? ...
I'm not a cooker expert, but try the following. Get a bit of electrical flex, strip the covering and part it so you have one fine strand. Poke this into the tiny hole in the centre of the jet underneath the ring and jiggle it about. The jets often get blocked by grease or a bit of dirt in the pipe same as the washers on a car. Costs nothing to try.
Jun 13, 2011 | Ovens
Please can anyone help? We are in a rented property and we have an NEB Venezia SS electric oven with gas hob and all the writing on the knobs has been erased over the years. The hob works fine we need to...
Look up the oven on the web the knobs vari in calabration figures so I have never worked on this model, try a search engine you may find a showroom near you pop in and have a look.
hope this has been helpful
John
May 31, 2011 | Ovens
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Whirlpool Oven AKZ101/1X serial 858510115001 140349004758
Ensure the oven knob is set to 0 (zero) and press the reset button in the middle
Oct 24, 2007 | Ovens
Ovens Logo
500 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
