Question about Admiral AW22 Top Load Washer
Water drains out of the bottom of the washer, not the drain hose
What's the problem ?
  • 1,031 Answers
Remove the top panel and the rear access panel and try to pinpoint the water leak.
check the return hose there may be a partial clog so all the water could not get out instead push out the other end of the hose only when draining and spinning.
Iif clogged then remove clog and everything will be okay ! I hope that helps
Posted on Nov 23, 2008
Water dripping under the rim, into the tub
Sounds to me like you have a siphoning problem You probably have your drain hose too far down in the drain pipe. When this happens the drain hose goes into the trap of the drain pipe. It then pull the water from the drain pipe back into your washer cause it cant break the vacuum. Pull your drain hose up so that on a little bit of the pipe is sticking down the drain pipe
Aug 25, 2012 | Maytag Washing Machines
How do I manually drain the water from the basin of my old, heap of a Whirlpool Model LSQ8543JQ0? It's out of here in two weeks, but in the meantime, I have no lid switch left on it, and it's full...
to manually drain it simply take the drain hose and hold it toa lower level athe the bottom of the tub(toward the bottom of the washer) and the water will drain right through the drain hose...depending on if ya have a floor drain to drop the drain hose into ya may need to raise and lower the drain hose several times intoa bucket...if ya have a floor drain put the drain hose in it and it will drain completly through that drain in the floor.
Oct 17, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Cabro WTW6200SW2 Top Washer. Water drains on the floor instead of through the drain pipe.
This one sounds like the drain pump is damaged or the drain hose is damaged or detached causing water to drain on the floor instead of through the drain hose. Disconnect power then tape the washer lid closed and lay the machine on its front on a cushioned surface to access the drain pump and the drain hose connections at the bottom of the tub. Reattach the drain hose if detached or replace it if damaged and cannot be reattached to the drain pump. Replace the drain pump if damaged and leaking water on the floor.
Mar 05, 2011 | Washing Machines
Water leaking from bottom, lots of suds.
Thanks for using FixYa. This may happen due one or more than one of these issues with your washer--
Probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
Unplug the washer to completely disconnect electrical power.Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
This issue can also be due to clogged drain pump or drain filter, due to which the hose have developed leak. This will cause suds
Please rate the solution if you find it useful and helpful.
Sep 22, 2009 | GE Washing Machines
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
How to drain water after laundry?
at the bottom of the washer is instructions on how to drain the water inside the washer. A small hose is contained at the bottom right hand corner with a white plug (you need to pull on it hard). Once you remove the plug from the small drain hose it will drain all the washer water.
Before you do all this make sure you disconnect the electrical wire or turn off the breaker switch to the washer machine.
Dec 22, 2008 | Samsung WF337AA Front Load Washer
Why does my washing machine have 2 drain outlets?
This is a water saver or previously known as a suds saver model. The bottom one is the drain. The top one would go to a suds tub. If you set the machine on save, the wash water is pumped out of the top hose into the holding sink next to the washer. The rinse water goes out the bottom hose to the drain. The next cycle you could set the washer to the very beginning of the main wash cycle and the washer would pump the water from the tub back into the washer to be used as wash water for the second load of laundry. Yea, used water. But the first load would be lightly soiled stuff, and the next load would be old barn clothes or play clothes. It was designed to save water (about 65 gallons used for 2 loads vs. 90 gallons) and soap. (now, front load machines with larger tubs would use as little as 25 gallons for two loads.) Just hook up the bottom hose to the drain. Leave the save / drain switch set to drain and you'll be fine. To be extra safe (in case the switch was accidentally set to save) disconnect the wires at the solenoid where the drain hose splits into two at the back bottom of the washer. (right where the hoses exit the machine.)
Oct 15, 2008 | Washing Machines
My washer has stopped on the drain cycle on three occasions. All three times pennys or dimes have made their way into the "drain hose" at the bottom of the washer blocking the hose or the last "hose connection device" before the actual drain hose that connects to the house drain.
Sep 17, 2008 | Fisher and Paykel Fisher & Paykel Washer
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer, while draining, leaks from the bottom.
remove the panel to observe the drain hoses while machine is in use. using a flashlight, locate the hose that you see leaking.
May 31, 2007 | Whirlpool LSQ8000 Top Load Washer
Admiral AW22 Top Load Washer Logo
64 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
