Question about Digi 002 Rack FireWire-based Pro Tools LE External Sound System
Unable to locate the unit on my G5
I have a Digi 002 rack that has just developed a problem. When I turn it on I here switching internally (like the sound I hear on startup when the lights cycle down from 96 to 44.1). This happened several times, and I was able to restore operation by turing off the unit and turing it back on.
  • Xtinasworld Jan 03, 2008
    I've been using this unit for 3 or 4 years without a problem, as recently as last night. This morning I flipped it on and the mute button lights up, the 44.1 light blinks once or twice, I can hear the internal clicking like it's looking for the FW/1394 connection...and then it just keeps clicking. Do I have the same power supply/DC harness problem? I have a huge deadline using this as a central tool beginning tomorrow---please help!
    Novelist:
    Champion:
  • 382 Answers
It's the power supply / DC Harness issue. A well known fault with the Digi 002.
Two things you can do:
Call Digidesign. They'll overnight you a new power supply and DC wiring harness free of charge, as well as installation instructions. They might also still be willing to do the repair for you (also free of charge), but that means you'll have to ship the unit to them, which will take considerably longer than the DIY approach.
Or, if you're REALLY stuck and you need to get back up and running RIGHT NOW (okay, within 30 minutes or so), you can disassemble the 002, pull the DC harness and clean the contacts with some Caig DeOxit, then apply a bit of ProGold, then put it back together... chances are that will clear up your problems and allow you to finish the session. :)
There are some good instructions on how to open up the 002 and what to treat over on the Digidesign User's Conference (http://duc.digidesign.com/postlist.php?Cat=&Board=UBB32&page=0&view=collapsed&sb=5&o=7) , but I can't locate them at the moment. But if you ask over there, I'm sure someone can refer you to the correct post. :)
I got one of the very first 002's in N America three years ago... and it worked fine for the first couple of months, then had the wiring harness issue... and Digidesign replaced it (via overnight delivery) and paid for the return of the defective unit. About a week ago, it went out again, This time, I got the replacement parts (including a small amount of the Caig chemicals :thu: - although I already had those on hand) overnighted to me. The install isn't all that difficult, but the placement of some of the locking tabs on the connectors is a bit difficult to deal with. Just go slow and don't force anything... a small screwdriver will help in "unlocking" some of those tabs. :)
Posted on Nov 06, 2007
My Digi 002 Rack is "Clicking" (the actual unit).
Hi
First thing to do is a hard reset. Merely unplug the power cord for 4 hours, then power up again.In order to dissipated the remaining current stored in the memory and disconnect all unit connected.
Regards:
votit
Feb 08, 2011 | Digidesign Digi 002 Rack FireWire Pro...
Hi i have digi design rack 002 with pro tools le
Try the other port on the 002. If that doesnt work, I recommend trying the 002 on a computer that does have 400 to see if it will connect then.
If it doesnt, then you may have a couple blown firewire chips inside your 002. It happens, and can be fixed.
Jun 29, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
Unable to locate hardware is what my mac says..... Power on
unable to locate hardware is what my mac says.all lights are on
May 14, 2010 | Digidesign Digi 002 Rack FireWire Pro...
Broken Digi 002 firewire port
Did you solve this problem yet. If not let me know im looking for a 002 to do some testing plus i need some spare parts.
Dec 19, 2008 | Digidesign Digi 002 Rack FireWire Pro...
Installing Pro tools LE 6.7 on G5
If this was already solved, well, this will help someone else. My guess is your new G5 came with 10.4 or 10.5 and you possibly tried to install LE 6.7 or earlier. This will not work on these OSs. If you have 6.7 you can upgrade to LE 6.9.1 for free and this will solve you problem. If you have LE 6.4 you are screwed and will have fork over $75 to Digidesign to upgrade to 6.9.1...or upgrade to 7.4, which is actually kind of worth it.
Feb 14, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi 002 rack
easy. Your clock got screwed by one of your audio programs in you system. It Happens when sample rates are mixes up. Leave your digi 002 on it does not set itself other than the factory sample rate setting when primarily switched on, which will remember its last setting if mixed up in an attempt to recover. Leave it on turn your system on. Then turn your system off. Not the digi. just your pc, mac. The software utilizing the previously screwed up sample rate will or should be reset. thus resetting your digi 2 to its factory 44. If it does not work check your software settings for any audio software set as default to run when pc is started ans make sure they are set to play back 44. Never turn your pc off when a program using your digi faulters.
Sep 08, 2007 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi002 Rack
Reinstall the driver with the unit dissconnected. Check to make sure your version of OSX is stable with your current version of Protools, especially if youve done any software updates.
Keep me posted.
Aug 30, 2007 | Digi 002 Rack FireWire-based Pro Tools LE...
"Unable to locate" 002 Rack Unit - sometimes!
Please help this guy and me too. I had the same problem. I emailed digidesign but cant get a good answer. I hpe this shit is not broken. I just bought it 2 years ago.
Sep 10, 2006 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi 002 Rack FireWire-based Pro Tools LE External Sound System Logo
429 people viewed this question
Top Digi Computers & Internet Experts
Alun Cox
Don Hart
Chris Larocque
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
