Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
If my lamp is out, would sound be present?
I hate to spend money replacing the lamp and that not be the problem. I have no sound, or picture.
  • 1 more comment
  • craigmcd58 Jan 15, 2009
    There is a slight squealing noise and then the red lamp LED blinks for 60-90 seconds and the TV turns off. No TV audio at all.
  • Anonymous Jan 19, 2009
    That is what happens when mine needs a new lamp. No sound just blinking light and no picture.
  • Anonymous Feb 20, 2009
    Mine blinks 3 times, pauses for 3 seconds, then blinks 3 times, etc. until the TV finally shuts off. Buying a new projector lamp did nothing to help. I'm thinking it may be the chip which has gone defective behind the power button.
  • 5 Answers
Check lamp cooling fan for dust blockage. It is located inside the back cover (10 screws) and is in a horizontal position above the lamp from the rear side. This is an air intake fan. The cooling fan you can see on the back panel is the exhaust fan that sucks out the hot air. A clue is hot or melt marks around the lamp housing.
If the lamp cooling fan is blocked you'll get red flashing diagnostics light flashing. It's trying to say clean me so I can keep the new lamp cool. Sony is silent on this in it's manuals. I'm guessing they don't care because is causes lot's of parts business!
I learned all this after replacement lamp burnt out after 1 week. My lamp cooling intake fan was found blocked and wasn't spinning. I saw the exhaust fan working and thought all was ok, not even knowing there were more fans. Some models even have another fan inside the optics blocker. I didn't take mine apart that far.
Posted on Apr 20, 2009
Yes my unit was like that after about less thank five minutes the pic would go away when you do replace the bulb make sure you dont lay the bulb slanted that makes the pic dark has to be standing straight in there easy to replace
Posted on Mar 01, 2009
Samsung HLR5067WX DLP - No picture, lamp light flashing
The colour wheel will not spin until the light has lit. The light will not ignite if the ballast unit detects a faulty fan, (checked) or the lamp door is open. The processor must be working as the lamp light flashes so I would say, ballast especialy if the lamp that came out is physically broken. Not cheap, even from flea bay!
Dec 06, 2013 | Televison & Video
Tv brightness/vibrant
Most of the projection lamps are recommended to be replaced after 2 years. The older they get the more dim they will become. I would suggest replacing the lamp again. Some of the aftermarket lamps do not work as well as the factory replacement. I always spend the extra money and get one from Samsung.
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
-TV does not power on. -TV has been plugged into multiple outlets with no success. Was working just hours before. Now no lights power on, nor does the screen.
It sounds like you have a bad power supply module part number BN96-03057A for a model LNS3241D. Please take a moment to rate my answer. Thanks..
Oct 16, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
PHILLIPS MODEL 64P842 HAS POWER NO PICTURE OR SOUND
I hate to say this, but this is why I've been trying to tell people here not to fix these sets. This is EXACTLY why I don't repair Magnovox any more. They just don't hold up to repairs. Those sets can have a bad small signal board or a power/deflection board. I'm sorry your having problems. Sound like the power/deflection board is working since you say it powers up. Some of those sets have a "daughter board" that plugs in on edge of the signal board "SSB" that go bad all the time. All the video and sound go through it. Just cut your losses and don't spend any more money on it. I hope it's something simple for you, but I'm affaid it won't. Good-luck.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Blue 1sq. ft area on left lower section on screen,
Greetings,
You said it yourself. You hate this set. My question is why did you bother to spend $900.00 to have it fixed when you could have bought a flat panel plasma or LCD set that would give you a better picture than any rear projections set could. My suggestion is since you hate this TV with a passion it's time to start looking for a new TV.
I know this is probably not the answer you are looking for but I would suggest that spending anymore money on repairs will most likely be a waste of your hard earned cash.
The blue spot is most likely either an alignment problem or a weak projection tube. Both problems will cost you unknown amounts of cash to repair.
Hope this will help to put the proper perspective on your problem.
Dec 09, 2008 | Hitachi 42V710 42" Rear Projection HDTV
Color went to grayish green, dull picture.
It ended up being one of the connectors on the composite cable. I did not know that the different colors came through separate cables. I do now, Thanks.
Dec 05, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Sony wega KF-50WE610 went dark...
If you have not changed the lamp in the 4 years you have had the tv you will need one soon if not now. is sound from tv or receiver, when the lamp dies usually no sound from tv. If you have sound from the tv try unpluging power from wall to reset and try again
May 16, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
No picture whirring noise shuts off and on
DLP(digital light processor) does not have a color wheel
Oct 05, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be gone and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Aug 11, 2007 | Sanyo PLV Z1 Multimedia Projector
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
1,039 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
