Question about Goodman CLJ30AR32 Air Conditioner
Janitrol gmp125-4, blower shuts off while burners still on,
Blower shuts off (and on and off) while burners still on,, replaced mother board but problem remains the same,, no blinks of the light on mother board, , always remaining red,,,, also replaced the capacitor , but still same problem persisits
  • 306 Answers
Sounds like fan motor is bad getting hot and opening the circuit inside the motor and then after couple minutes cools off enough to complete the circuit and runs for little while and does it over and over.
Posted on Nov 26, 2008
  • Ken Bledsoe Dec 17, 2008
    What was the problem with your unit? ken
What's wrong with my furnace?
The relay for the motor is stuck or the points inside the relay are arced closed. Replace the relay.
Apr 26, 2016 | Goodman Janitrol Amana Goodman Janitrol...
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
Feb 03, 2015 | Heating & Cooling
Janitrol furnace. burners ignite then shut off, blower runs but no heat
Sounds like a dirty flame sensor. On the opposite side of the Igniter will be a metal rod that is just above the burners, you need to remove this rod and clean it with a steel wool pad. Then reinstall it and turn Furnace back on. If this does not help let me know, it may also be a high limit switch tripping.
Nov 28, 2012 | Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Janitrol GMP 100-4 replacing blower new blower has extra yellow wire. do I just not connect it
Look on the motor wiring diagram, being that it is yello would lead me to believe that this is
a muti-speed blower. If this is true, look for a place on the terminal board that says "Park"Otherwise make sure you tape it off and move it out of the way
May 26, 2011 | Goodman Furnace Draft Inducer Blower ...
I have a Goodman GMH950904CXAC. Thermostat calls for heat. It comes on and runs fine for about 5 minutes, then the circulator blower shuts off, but burners and draft blower still run. After another 15...
4 flashes is an overheat situation most likely caused by the blower not blowing. The blower relay controls the blower function. It is part of the circuit board. I suspect a new board will take care of the problem if you don't find a lose wire or something simple.
Feb 27, 2010 | Goodman Heating & Cooling
We have a Janitrol gds80904bna less than 3 years old. We have had several repair people out here and none have a clue why the unit keeps running. No heat. Just fan. They want to replace several parts and I...
Make sure that there are no wires connected to the G terminal on the circuit board. There is a blower relay on the circuit board that is probably bad, replace board.
Dec 26, 2009 | Goodman GDS80904BNA Open Flame Heater
I have a GMP100 furnace and I replaced the control board because the blower fan wouldn't kick off now and then. It all works great but the main blower only stays on about 45 seconds after the burner turns...
Check the board for a set of dip switches. Check against the old board for switch positioning. These control fan on/off times. Ensure you turn power off before changing switch positions. If no dip switches,??
Dec 04, 2009 | Refrigerators
Goodman gas furnace
Sounds like it coud have been a flame sensor. the limit switch is usually near the top of the heat exchanger.
Nov 02, 2008 | Goodman Heating & Cooling
Goodman CLJ30AR32 Air Conditioner Logo
184 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
