Question about JVC TH-M505 System
Sounds but no bass
My speakers work but the main speaker that product the bass does not work. Please someone tell me that the amp in it is not problem and it is just a setting I need to change.
  • james hailey Jun 22, 2007
    Ok so what if its da amp. Can it be a fuse or something like dat.
  • kyleraybrown
    kyleraybrown Aug 24, 2012
    you might have a bad s video cable that runs from your sub-woofer to your reciever cause i had the same problem and i had to buy a new cord now it bumps
  • 203 Answers
Check your setting for the sub first. If that doesn't pan out it is likely to be the amp.
Posted on Jun 15, 2007
How come the sounds from my main speakers coming out only on the small soft ball.
you need to either add the tweeter/bass bridges or your bass drivers are gubbed
Nov 23, 2014 | Mission M73 Main / Stereo Speaker
Output distortion from bass amp
The amp is clipping the signal. This could be from the input being too high. The impedance being too low or the finals are damaged.
Dec 11, 2017 | Behringer BXL1800 180W 2-Ch Bass Amp 12In...
I have a system installed and i have mtx speakers plus mtx subwoofers i want to know how could i take the bass of the speakers because it sounds horrible when loud
if you turn the bass setting in your radio down it will take the bass out, but may take some of the bass out of the subs as well, if this occurs and you still are not satified, you either have to get a car receiver with a non fading subwoofer preout, or you could get bass blockers for all the speakers you dont want the bass in
Apr 05, 2012 | MTX Car Audio & Video
The power light is on but the sub not playing at is also a kicker product. A 12 inch sub all wires are in the right place a audio shop did the work for me. Can you please tell me what is going on.
Is your sub in a box? the power light is on your amp? try to connect a car speaker to the port you have the sub plugged into, if the speaker works its not your speaker terminal on your amp it's the sub. Check the wiring on the connectors of the back of the sub itself and the wire terminals inside the box (if sub in bass box)
Please let me know if this was any help and let me know if it solves your problem
Mar 05, 2011 | Kicker Car Audio & Video
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
Do large speakers have to be in front
This being a generic question, I can only provide a generic answr:
In multichannel rigs the question of Large vs Small denotes nit the 'size' but the ability to handle bass - Large presumed to be bass-capable. When you identify a particular speaker as 'small' in an AVR you're telling it to redirect bass to either the Subwoofer or the Main Speakers if they are 'Large'. Some AVR's also allow sharing the bass with the sub instead of having it all go there. If you have large speakers configured for bass the realism of surrounding bass sounds is better.
You can have many combinations of Large vs Small speakers in most AV setups but there usually are some dependencies. For example, bass can't be directed from one 'small' speaker to another; or if you select 'small' for the front speakers a Sub is presumed to exist.
I have all large speakers in my set.
Dec 25, 2010 | Audio Players & Recorders
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
Main Bass speaker not working!!
Hello Adam Hi, it looks like your main IC amplifier inside the main bass box is bad, need to replace that IC. What are your plans, do you want to do the repair or have it service by a tech guy.
May 06, 2010 | Bose Companion 3 Computer Speakers
My son's guitar amp Epiphone guitar amplifier model ep-800, does not work after someone plugged a bass guitar on high settings. He tried it the next day, only to find out it didn't work. Could the bass...
it could have blown the speaker, a regular guitar amp is not meant to handle a bass, you should be able to look into the back of the amp and see if any of the speaker is damaged, or there may be a blown fuse inside the amp, if you check for this please MAKE SURE TO UNPLUG THE AMP FROM THE POWER SOURCE FIRST, and if needed replace the fuse with the exact same type
Mar 21, 2009 | Music
Tweeters & Midrange Speakers
If you have a Ohm Meter, check the resistance to the speakers. If it is very high, the speakers are burned, (or the crossover is (just capacitors, and resisters...cheap)). If it is close to 4 ohms check the wiring and connectors..to and at the speakers, most likly the receiver/amp is not blown.
Apr 20, 2008 | KLH 1230SB Main / Stereo Speaker
JVC TH-M505 System Logo
85 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
