Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
How many belts does it have and were do they go
I do not know how to put my belts on
  • realtorbob Nov 23, 2008
    have windtunnel sweeper, no idea how to replace the belt
  • pritzc Dec 14, 2008
    Don't know how to replace the belt to turn the brushes. HELP!
    Last time I took it to the Hoover Service Company and was charged about $30.00 for replacement.
Its very easy, where the brush unit is - their are 4 screws, unscrew them and you will see the belt
Posted on Dec 31, 2008
I need to know how to put on the vacuum cleaner
Remove the brush bar. Then link the belt onto the motor spindle. Then insert the brush bar into the belt and snap it back into the vacuum chassis.
May 02, 2010 | Vacuums
How do I put a new belt on Hoover Concept One vaccume cleaner?
you most likely have to remove the cover over the roller, which has screws usually. then you will see the belt. the roller slips out replace the belt by putting it over the roller and a metal rod that is up under the cover you removed. this will be a hard job putting the roller bar back in the vacuum because the belt is so tight.
May 18, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
Installing a belt
1. Unplug the vacuum
2. Take the bottom cover over the brush off by removing the 3 screws
3. Switch the brush roll control lever to bare floor
4. Take the roller brush out
5. Put the belt around the small pulley from the motor
6. As you are putting the roller brush back in put the belt around the space on the roller brush - center the belt on that space - THE BELT WILL NOT BE TIGHT BUT THAT'S NORMAL
7. Reinstall the bottom cover with the 3 screws
THE BELT DOES NOT GO AROUND THE SILVER PULLEY CONNECTED TO THE BRUSH ROLL CONTROL LEVER
Dec 27, 2008 | Vacuums
How do i know if i put the vacuum belt in right
put the belt on as you best can then spin the brushroll several times. if all things seem smooth thenyou have the belt on right.
Sep 27, 2008 | Kirby Vacuums
How to replace a belt successfully on a Bissel Powrforce 3522?
How do I replace the belt? I don't know how to get into that area.
May 21, 2008 | Bissell 3522 PowerForce Bagged Upright...
My belt broke on my kirby upright, I took the roller off and put the new belt on, but I cant get the hook to hook on the belt.
On the front of the nozzle is a big knob that you turn to load the belt. Take the nozzle of of the vac, turn the knob to catch the belt, keep turning it until it stops. You will know if the it caught the belt, it will be hard to turn. Put the nozzle back on, lock, then turn the knob in the other direction releasing the belt unto the pulley.
May 01, 2008 | Vacuums
Pump belt on bissell scrubber
If this is a Bissell Pro-Heat, then first take the belt cover off, it is on the left side on top of the noozle. Then turn it over, take out the one screw from the red lock, pull it off, then remove the cogged belt, take out the old pump belt if still on from underneath. Put a new one over the pump end, then feed it thru the opening and put it over the motor shaft. Put it all back together.
Feb 25, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Hoover windtunnel
Put the V belt on the pulley first, then the flat belt, put it over the motor shaft or pulley, then you have to stretch it to go over the pulley next to the V belt pulley.
Jan 18, 2008 | Hoover U6616-900 WindTunnel Bagless...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
