Question about Sony Cyber-Shot DSC-P73 Digital Camera
Camera is making strange noise
I'm not sure what happened but. I finally got some batteries for my camera, but when I put it in and turned it on, it does this whizzing noise and it won't turn on the camera, the noise only stops when I put it on 'setup'. What's wrong with it? im pretty sure I never dropped it badly or spilled water or anything.
  • kammy nxtus Dec 28, 2006
    Nevermind, the shutter is stuck....
    Problem Solver:
  • 36 Answers
Good Day, lens assy problem, no longer user serviceable, contact nearest svc ctr. thanks
Posted on Sep 03, 2007
After charging camera makes a strange noise
it may be the focus resetting to its start position for the next picture..
Mar 06, 2014 | Nikon Coolpix S6100 Digital Camera
Blurry pictures and beeping noises
It could be the lens is damaged on the inside (Gears and so).
But before you make any conclusion. try to switch the camera to auto mode and make sure the camera is not in the macro mode.
To start, switch of the camera, remove the batty and leave it out several seconds. perhaps you also should charge the battery on an external charger,but if you are sure it is charged, after a few moment reinsert the battery. Then switch the camera to the automatic mode and check if it is not in Macro. (when you see the flower on the screen it is in macro)
If it is still acting the same you made the right conclusion in the question above. (I hope you are wrong but if not, you start looking for another camera)
Jan 26, 2014 | GE J1470S Digital Camera
My camera will not power on - the red light flashes. I charged the battery this has never happened before...
The flashing light indicates it is not making it through it's self test without an error. Has it been exposed to something strange? Customs perhaps? The other thing is to go to a battery shop and ask if the battery is ok? I had this happen when the camera had been in storage a long while. no one recalled what happened. I put the camera under a warm light 100watt bulb 12inches above on a black cloth for one hour. battery out. then I put the fresh charged battery into the warm camera and it came back to life. I figured it's internal battery was drained and warming it was just enough to power through the self test.
Feb 20, 2011 | Olympus Stylus 770 SW Digital Camera
Strange noises
This camera has an auto lens. Which means it will focus automaticly evey sec. you can turn this option off:
1: Go into the menu
2: Chose option Cam Setiings
3: Swich AUTO focus to single lens and click OK.
Dec 10, 2009 | Kodak Easyshare M341 12.2MP Digital Camera...
DSC-S950 camera problem help!!!!
There is definitely some sand or dust stuck in the lens well between the body and the lens housing. Use your vacuum cleaner to pullout the dust particles from there. It is this stuckup dust that is making the noise. Also while pulling out the dust keep powering on and off the camera.
Nov 05, 2009 | Sony Cybershot DSC-S950 Digital Camera
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
Jul 02, 2009 | Olympus FE-280 Digital Camera
My camera will not turn on
I have the same camera. And it happens sometimes. Make sure you put batteries for digital cameras and not alkaline batteries, those are not powerful enough. Make sure that the polarity is good. I don't see what else wouldn't work.
Jul 02, 2009 | Kodak EasyShare C743 Digital Camera
Canon dvd camcorder DC210
Ok, Guest @ solution #1 and #3 solved this for me.
Step 1. remove battery pack.
Step 2. Plug in to outlet.
Step 3. Insert desired disc.
Step 4. Toggle down on the "mode" lever for "Play-back" mode.
Step 5. Press "function"
Step 6. Scroll to and select "menu"
Step 7. Scroll to and select "disc options"
Step 8. Scroll to and select "Finalize"
Step 9. Scroll to and select "Yes"
Follow prompts from there.
This worked for me.
Thank you all!!!
Sep 23, 2007 | Canon DC210 DVD Camcorder
Camera making strange noise
Sounds like the focus mechanism, your camera will be a very light sound while focusing. this is totally normal and nothing is wrong with your camera the sound is a good thing it makes sure your photos are in focus :)
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony Cyber-Shot DSC-P73 Digital Camera Logo
74 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
