Question about Canon PIXMA iP4300 InkJet Photo Printer
PRINTER WONT DO ANYTHING
MY PRINTER WILL NOT PRINT AND THE MAINTENANCE LIGHT IS FLASHING 5 TIMES THEN STOPS THEN AGAIN AND SO ON
  • mlb49 Dec 19, 2008
    hi - i have the same problem. 5 amber flashes. ip4300 won't print and pop-up message says it's "operator error"
    Early symptoms: warning that ink cartridges were low, so i printed in B&W. Printer sat for about a month with no printing - and then the "operator error" messages started. Looking at the ink cartridges the yellow, cyan and magenta were all blinking. The warning light was flashing 5 times - indicating a damaged print head.
    I purchased all new ink, and then did all the suggested solutions: cleaned the print head, but neither the resume button, nor the paper feed buttons work. Could not clean print head, could not deep clean print head using the printer.
    I don't think it's the printer head - it hasn't even printed a ****'s worth of paper - but it's beyone warantee period. Anyone know any tricks to help me print again?
    Many thanks -Mary
    Problem Solver:
  • 12 Answers
Take the printhead out and run it under hot water.
Don't worry about getting the copper colored metal wet.
Set it to dry and reinstall into printer.
This has worked for me and others in the past.
Seeing as this error calls for a new printhead you have nothing to lose.
Posted on Jan 21, 2009
Hl1440 drum indicator flashing
ok turn it off take the toner out clean all the terminals put them back in make sure everything is closed properly turn the machinie back on and let me no what happenes then
Sep 12, 2008 | Brother DR-400 Replacement Drum - 20000...
How to remove the ink cartridges?
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
Apr 04, 2011 | Epson Stylus C43UX InkJet Printer
C45 how to clean nozzels
You can print the print head using the Control Panel buttons;
1. Make sure that the fontp.gif power light is on and that the font28.gif error light is off. 2. Hold down the font28.gif maintenance button for three seconds. The printer starts cleaning the print head and the fontp.gif power light begins flashing. Important - Never turn off the printer while the fontp.gif power light is flashing. Doing so may damage the printer. 3. When the fontp.gif power light stops flashing, print a nozzle check pattern to confirm that the head is clean.
Mar 06, 2011 | Epson Stylus C46 InkJet Printer
Maintenance warning/technical issue message stops printing
You just need to reset your printer. Google search a resetter program for your printer model.
Jan 10, 2010 | Epson Office Equipment & Supplies
I need to clear the inkjet heads on my Epson Stylus R220.
Follow the steps below to clean the print head using the Head Cleaning utility.
Make sure that the printer is turned on and the ink out light is off. Access the printer software. Click the Maintenance tab, then click the Head Cleaning button. Follow the on-screen instructions. The power light flashes while the printer performs the cleaning cycle. Never turn off the printer while the power light is flashing. Doing so may damage the printer. When the power light stops flashing, load a few sheets of paper and click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Apr 21, 2009 | Epson Stylus Photo R220 InkJet Printer
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
Printer
One of the best solution that we can provide you is head cleaning. One of the effective method of Head cleaning is listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START. Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) , your printer will require service.
Jun 03, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Black ink
Please try the following to resolved the issue:
Run a series of head cleaning
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
3. Click on START, CONTROL PANEL, PRINTER & FAXES then right click on CX3200 printer Icon then select printing preferences
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 02, 2008 | Epson Stylus CX3200 All-In-One InkJet...
CANNON IP5200
According to the service manual, that is an 'ASF (cam) sensor error' and solution being to replace the 'Sheet feed unit'.
Jan 18, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
257 people viewed this question
old marine
old marine
