Question about Kenmore Oasis HE 27082 Top Load Washer
DU on display readig
Just replaced lid lock. Getting reading for wash 50 then changes to dU on dislplay how to clear that off?
  • 5,911 Answers
In reference to this problem, I have already posted a solution under another posting of yours, but failed to mention that you may also try unplugging the washer for at least 30 minutes FIRST. In some cases, this is all that is required to clear momentary glitches with the control board. If the problem is not as simple as that, please follow the advice I provided to you and let me know if you need further assistance.
Posted on Nov 24, 2008
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/dU error code on...
The F/dU is shown on the display due to Door Unlock Error in the washing machine.
In this problem check the Door Lock in the washing machine. Either the door is getting blocked or not getting locked or the door latch assembly is got cracked.it needs to be checked and replaced.
This will help. Good Luck.
on Mar 11, 2010 | Washing Machines
I am getting the code on my frontload washer F du, it is making a clicking sound the water starts to fill , then the code comes up..I am not able to find this code in my manual ..I am thinking that maybe...
The DU in the display is an error code for the door lid not unlocking. This is an indication that the lid lock assembly has failed or the control board is unable to determine if the lid is unlocked. This usually indicates that the lid lock assembly will need to be replaced.
http://www.servicematters.com/maytag_library/docs/16007803.pdf
Service manual above.
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
Du f flashes as code on whirlpooll whasher??
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
DU is flashing and when I press the Pause/Cancel button this does not clear the problem
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
If it is a cabrio:
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
DU on display
Okay...it took me a while to find this information and make some sense of it. The "50" indicates a motor stall. That means the RPS sensor (which is located near the main drive motor ) does not sense any movement of the main drive motor under the wash tub. This could be related to your next error code which is the "DU". This is an "Door Unlock" error. You will need to perform the following checks if washer fails to lock (or unlock).
2. Remove the console to access the machine/motor control assembly. This is accomplished by loosening the three screws in the back of the console. With the screws loosened, the panel lifts from the back first. Use care when handling as there is a small connector that connects to the operator interface board.
3. Locate the machine.motor control board on the right hand side (as viewed from the front of the washer). Visually check that the P12 connector is inserted all the way into the machine/motor
control. (There are three connectors on the right hand side of the control board. They are labeled as follows: BROWN (P10), BLUE (P11), and ORANGE (P12)
motor control and checking the resistance values shown in the Lid Lock resistance table below:
Motor Winding - Check P12-2 to P12-3 - 26 ohms (Lock Switch locked and unlocked).
Lock Switch Home - Check P12-1 to P12-4 - 0 ohms (Unlocked) Open Circuit (Locked).
Lock Switch Lock - Check P12-1 to P12-7 - Open Circuit (Unlocked) 0 ohms (Locked).
Lock Switch Lid - Check P12-1 to P12-5 - Lid Open (Open Circuit) Lid Closed (0 ohms).
LID LOCK RESISTANCE
If resistance values are good, proceed to step 5. If the switch measurements ae incorrect for unlocked (or locked) conditions, a problem exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power. Replace machine/motor control assembly.
There should be a tech sheet inside your washer that you can also get this information from. I have referenced these steps from the tech sheet. To access, you can either lift the washer from the front and reach the inside the cabinet from under the washer, or lift the top panel by pushing in on the release tabs. This is accomplished by inserting a putty knife along the seam where the top meets the front about two inched in from each side. Push in while lifting to release the tabs. CAUTION: Make sure you hold on to the washer lid to prevent it from swinging open as you lift the top.
The tech sheet is located on the inside of the front panel of the washer between the wash tub and cabinet interior. I mention this as there are helpful drawings and more detailed explanations to assist you. This can help avoid confusion from me explaining these steps to you. Since you mentioned you had just recently replaced the lid lock, you may double check your work to make sure you have everything reconnected correctly. Barring you purchased a bad part...if the lid lock proves to be good, you may have a defective control board.
I do hope you find this information helpful. Let me know if you require further assistance.
Nov 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washer keeps reading Du
sounds like lid lock failure clips each side just below top eadge of washer about 3-4 insches from outside edge use stiff putty knife to push clips in and release top should be able to acess switch from there swtich will need replacing
Apr 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool cabrio HE error code
The problem with this is the lid lock is broken i suggest replacement of the lid lock to solve your problem
Jan 14, 2008 | Washing Machines
Locked Lid, error code "du"
blat, unplug the washer for 30 seconds and plug it back in. Hit the power key and do the following: press any key except for power, start and stop in this order, press and hold for 3 seconds, release for 3 seconds, press and hold for 3 secnds, release for 3 seconds, press and hold for 3 seconds. The 88 should light up in the display if done right. While the 88's are showing (you have about 5 seconds) press the same key again. You are now in the manual test mode. Now by pressing the 2nd rinse or xtra rinse button, you should be able to lock and unlock the door mechanism. You can check the p-12 harness on the main board to make sure it is seated all the way. This test proceedure has to be done pretty precise or it will fail....Catriver...post back.
Nov 25, 2006 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
