Question about Sony KP-43HT20 43" Rear Projection HDTV-Ready Television
Sony KP-43HT20 ghosting effect.
My Sony KP-43HT20 has a ghosting affect on all the words on the tv and there is a faint red line on the left corner of the screen there is also a faint red line on the right bottom corner of the screen. Sometimes i see blue and green on the screen too. Please tell me what is wrong with my tv and if possible teach me how to fix it or please tell me the price it will cost aproximently.
  • jimcrocefan Nov 09, 2007
    Ghosting occurred all at once while watching tv. It occurred when changing a channel and has not corrected. I turned power off at the strip but it had no effect. I checked picture from DVD player but it was the save so I know it is not the cable service. Ghosting is mostly in red. Is it repairable at a reasonable cost?
  • richie ross Nov 18, 2008
    We were watching TV and all of the sudden the picture went into a 3D type image without the glasses. Is there a fix?
    Sergeant:
    Champion:
  • 346 Answers
The red color control needs to be adjusted
Posted on Nov 04, 2007
I got one likes that. I have fixed mine by changing only one IC 8001. After my TV operating about 20 days, the problem come back.It might be the quality of the IC STK 392-56. Because IC production made by Sanyo ???
Posted on Mar 31, 2007
May have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Posted on Dec 28, 2006
I have a sony projection tv kp-43ht20 and the picture has gone pink. Can you give me an idea what has happened? Is this a fixable problem? I can't afford a brand new tv at this time. Thank you for your...
Sounds like the convergence is out of adjustment....moving the set can cause this as well as components chaging value with age....The kp43ht20 is an older set and may not have the alignment setup in the menu as with the newer sets...but you can go thru the menu to find out...if there is one, then you can try to align the convergence...usually there will be a crosshatch on the tv...when aligning convergence there will be a blue setting and a red setting...you want to select red first and try to get the lines lined up as close together as possible on the red adjustment..then you go to the blue adjustment and do the same...the outcome should be as close as possible to white when everything is lined up properly
Dec 30, 2010 | Sony KP-43HT20 43" Rear Projection...
Colors don't line up, and screen is distorted on a sony KP43HT20
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 08, 2009 | Sony KP-43HT20 43" Rear Projection...
Is a sony big screen tv model number kp43ht20 a hd
Yes.The best way to hook up this set is using the Component input (R,G and B inputs) with red white for audio
see link to specs
http://www0.shopping.com/xPF-Sony-KP-43HT20
Oct 30, 2009 | Sony KP-43HT20 43" Rear Projection...
Green ghosting on the side of images, sony kp43175
this could be caused by a magnet thats too close to the tv, like in an unshielded hifi speaker. if not, then a degausing component if faulty and needs replacing by an engineer.
Jul 17, 2009 | Sony KP-43HT20 43" Rear Projection...
"ghosts on sony projection tv
Hi friend
its colour wheel problem you should change it,,,first check if any burnt parts resistors,,,,,common problem is colourwheel,
check it...........thank u,,,,,,
May 03, 2009 | Televison & Video
Red red wavy lines across the TV screen
I did not fix the problem, but you have the model number wrong, it is KP-46WT510
I do need some help.
Nov 23, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony color rear video projector KP-43HT20
get the tv degaused that should fix the problem
Jul 23, 2008 | Sony KP-61V45 61" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43HT20 43" Rear Projection HDTV-Ready Television Logo
323 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
