I need to pull out my fitted washing machine, but can't budge it
It is sitting on blocks of wood, and i can't move it. Am i missing something?
  • Washing Mach... Master
  • 3,463 Answers
Hi.
It is just probably stuck on the wood.
Just give it a good tug, and that should free it.
Posted on Nov 23, 2008
How to remove front wheel have removed all studs but wheel won't budge
use a block of wood and a 4lb hammer sometimes the rim is so close fitted that you needs to hit it
Apr 07, 2018 | Cars & Trucks
Lamona hja 8553
Unfortunately Lamonoa doesnt make washing machines. Its a wood fitting company that uses various machines. They reccomend this manual
http://pdfsb.net/readonline/5a6c4244656739355758422b436e6c6a55554d3d
for the 8553.
You have to read online..through the pdf
Mar 20, 2014 | Washing Machines
Leveling kenmore elite front loader
  • Place the level on the top of the washing machineicon1.png to see if it is level. Make sure you test it side to side and front to back.
    Pull the washing machine away from any walls if you have to make an adjustment to the legs.
  • Lift the washericon1.png and place the wood block underneath the washer. Place the block near the leg that needs to be adjusted, but don't let it obstruct the leg.
  • Loosen the nut that secures the legicon1.png with the wrench.
  • Raise the height of the leg by twisting it to the left, or lower the height by twisting it to the right.
  • Remove the block of wood from under the washer and recheck the machine with the level.
  • Raise or lower the leg if additional adjustments are needed.
  • Tighten the nut on the leg with the wrench when the machine is level.
  • Repeat the process for each leg that needs to be adjusted.
  • Move the washer back into position and check with the level again to make sure the washer remains stable to finish leveling the machine.
    Regards,
    Richard Roth
    http://appliancecafe.com
  • Nov 13, 2012 | Kenmore Elite 45986 Front Load Washer
    My Aqualtis AQGMD149 has the fault that it is blocked. I cannot remove the cover to clean the pump out. The manual says unscrew it anti-clockwise but it only goes a quarter of a turn and won't budge. ...
    Try pulling the filter after you have unscrewed it. Often there is a large rubber sealing ring on the perimeter of the filter drawer so it has to be pulled quite hard to remove it.
    Feb 28, 2011 | Washing Machines
    Mandril keeps falling out while drill is operating
    follow closely, get something like brake clean and spray both parts the internal socket and the mandrel, wipe clean with a paper towel and then move the table out of the way and retract the jaws of the chuck and find a block of wood and a hammer and putting the mandrel back into the socket and the block of wood on the chuck body strike it a couple time with the hammer to seat the chuck. it is a taper fit and has to be clean before it will stay. Let me know if you need more assistance
    Dec 16, 2009 | Drills
    GE washer model WJRE555OH1WW - agitator free-wheels.
    First make sure the inner part of the agitator is not brocken.
    Remove the soap cap from the top of the agitator and with a torch, look down into the shaft. There is normally a nut which secures the agitator to the gearbox shaft. If the plastic around the nut is broken then the agitator moves freely.
    There may not be a problem with your gear box, then and relatively cheap to replace agitator.
    goodluck.
    Ash
    Oct 22, 2009 | GE Washing Machines
    Trying to remove the Timing Chain case to reveal the last 2 head bolts. I removed all the bolts, studs and cam gears but it will not budge. Is it pressed on or am I missing something?
    It sounds like you got everything. Sometimes they stick from being sealed for so long. Try tapping on it with something like a rubber mallet or placing a peice of wood on it and hitting the wood with a hammer that might break it free so you can remove it. If this helped please give me a thumbs up! Thanks
    Sep 24, 2009 | 1997 Chevrolet Cavalier
    Washing Machines Logo
    258 people viewed this question
    Top Washing Machines Experts
