Question about Samsung ML 1210 Laser Printer
Very Noisy Warmup cycle with my ML1210
The printer works perfectly, except lately it has started to get noiser and noiser during the initial warmup cycle. After a full night, in early morning, when the printer is cold. The warmup cycle sounds like gears are grinding, clattering. Finally it warms up, shuts down and then prints perfectly. Could there be something loose in the gear or drive system that only is a problem during this warmup cycle? Is there some way I can adjust or tighten something to repair this? Thank you, Fred G.
  • Anonymous Dec 31, 2007
    Ours does this too and now it does it when it's actually printing. I believe it has something to do with the gears that feed the paper through but we can't find anything. It's printing fine, but this printer is only 6 months old. I can't believe this is normal operating noises.
  • Anonymous Mar 17, 2014
    Warmup cycles every 20 seconds (therefore not a quiet printer). Other than that it prints fine.
Put your ear closer to printer to detect source of noise, put all gears out and check each one and reassemple them, I hope you solve your prob.
Posted on Jan 01, 2007
Samsung clx-3175fw stuck in warmup mode
replace it , its having some kind of hardware problems
Nov 11, 2013 | Samsung CLX-3175FW Multifunction Laser...
496 mag runs rough during warmup cycle
Go up on gas octane to 89.
Jan 01, 2018 | Cars & Trucks
Canon Imagerunner C2620 stuck in warmup
you must read your troubleshooting section instruction manual If you do not have download
www.fitness.manualsonline.com or www. retrevo.com or www.manualsfactory.com or www.2manuals.com or www.eserviceinfo.com
see the diagram .God bless you
May 09, 2012 | Canon imageRUNNER C2620 Color Copier
C 2101 on bizhub c451
this error code means there is charge cleaner malfunction. during the backword movement if the cleaner the home sensor was not actuated after a predetermined amount of time. to reset the error code leave the machine on and open then close the front door if the charge cleaner motor has been disabled in service mode this error code will happen at start up
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
Warmup never completes, no steam comes out
I think your model only has one boiler, it is possible that the thermostat for the steam could be damaged. or on the mainboard, connection that turns the steam on is damaged(I had that happen on a compact digital).
Jul 07, 2009 | Saeco Magic Comfort Plus Espresso Machine
My Mtsubishi TV needs a new light engine...cost $799?
If one of your 4 fans stop working you will get a red blinking light. These do go bad after awhile. Part is under $10 at an electronics parts store if it is a fan. You have to open up the back and see if all 4 fans are working. If the light comes on after initial warmup then it is probably the main exhaust fan on the back cover of the tv. If it comes on during warmup period, then it could be your chassis fan. These are the two fans that usually will go bad.
Jun 19, 2009 | Mitsubishi WD-52327 52" Rear Projection...
MAGICOLOR 2400W WARMUP CYCLE
probably, it need a little maintance, maybe some part needs to be replaced. so if you still have a warraty, use it. because there can be many problems, what makes noise.
good luck
Jan 13, 2008 | Konica Minolta magicolor 2400 Laser...
Start up cycle continues?
This is the normal start up procedure. The green light will continue to flash until it has completed the startup/warmup rpocedure.
Oct 15, 2007 | Epson AcuLaser C900 Printer
Printer stays in 'warmup cycle and stop' and repeat over and over again
AC, this link should take care of your questions. You can download the manual and check out the specs. http://www.samsung.com/support/productsupport/download/Model_Select2.aspx?type=Printer+and+Multifunction&subtype=Discontinued+Products&model=SCX%2D4100&fileType=UM&LSSI=%2Finclude%2FSSI%2Fus%5Fleft%2FLMenu%5FPrinterandMultifunction%5FDiscontinuedProducts%2Esec&RSSI=%2Finclude%2FSSI%2Fus%5Fright%2FRMenu%5FPrinterandMultifunction%2Esec Good Luck, Tim
Feb 03, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung ML 1210 Laser Printer Logo
243 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
