Question about Kenmore 18 in. 14432 / 14439 Built-in Dishwasher
Door won't close
Kenmore dishwasher. All of a sudden, I keep pushing the door but the latch won't click it shut.
Therefore the machine won't run. I need to know how to open the inside panel so that I can fix the latch.
  • Anonymous Mar 22, 2014
    kenmore dishwasher door latch wiring
    Sergeant:
    Champion:
  • 338 Answers
First see if under the counter it a metal catch sticking out and make sure it is lined up to go into the hole in the door. if it is then look in the hole on the door and if you see a small white piece sticking up you may be able to stick a screw driver in to push it back in place. .if not then you have to take all the torx screw out of the door panel at the top i believe its either 6 or 8 screws then try and pull the panel off.. if it doesnt come off then you will need to take the las 4 torx screw out and seperate the inner door panel from the outer door panel and you will see everything you need. let me know if you need any clarification.
Posted on Nov 29, 2008
Why do no panel lights turn on when my Kenmore Model 587.1625 is latched and ready
The door latch in Kenmore and Kitchenaid isn't of the best design.The spring steel latching tab is needs to push down the black plastic slide mechanism when the door in closed. That slide pushes down on a micro switch which interrupts the cycle when you open the door when the dish washer is running. Take the latch assembly back out. You can insert two compression springs inside the slide on each side of the latch. They are approx 3/16 Dia x 3/4 to 1 inch long. In the hardware dept at Home Depot or Lowe's..The springs will push the slide down hard enough to activate the switch. Right now your dish washer thinks the door is open.
May 17, 2014 | Dishwashers
Whirlpool dishwasher door will not click shut to allow washing cycle to start
Check to be sure the gasket that is between the unit and the door is in its proper palce, it may be knocked out of its normal spot and keeping the door form closing all the way where the latch would engage.
Apr 22, 2013 | Dishwashers
When the machine is switched on there is a clicking sound from the door and the machine won't start. Opening and closing the door and giving it a thump, works after 2 or 3 attempts. Is the problem
Had a similar problem with our Kenmore front load washer, our grandson was caught leaning on door while it was open and it bent the hinge slightly, this misalignment resulted in the latch mechanism trying to lock the door shut( needed as a safety measure to prevent leakage) but it was unable to do so. Had limited luck with lifting the door while shutting it and holding it closed while pushing the start button,but eventually had to replace hinge. Parts man at service desk also advised not to hang wet heavy items on door (don't know why anyone would want to) as the same thing could happen,also don't try slamming door as that could result in costly latch replacement. Hope this was of some help
Feb 24, 2013 | AEG Lavamat 74640 Front Load Washer
Less that 2 yrs old..door wont latch. As a consequence machine won't start.
It is possible the door latch is faulty or the springs at base of dishwasher are soft and need adjusting. the springs keep the door in position. refer this site for parts.
Dec 31, 2012 | KitchenAid KUDS30IXBL Builtin Dishwasher
Washing machine won't start
Check your door when it closes, it should hit a push-in button above that door latch, at times I have seen the door hinge bent down just some, causing the door not to strike that button dead on.
If thats fine, then its likely to be the door latch assembly or the CCU board bad.
Oct 14, 2012 | Kenmore Washing Machines
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
The door on my machine won't shut?
Hello
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Neff dishwasher door problem.
May 21, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Bosch Dishwasher SHX46A latch stuck in down possition.
look at the latch via the hole in the door where it closes to the tank? is the latch faced away from the tank? if so, then grab a paper clip and fold it so you can hook it around the latch then just pull outward towards the tank. you might need to hold that paper clip with some pliers. if it happens more than once then you will need to replace that door lock.
Mar 18, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Kenmore dishwasher 665 15752 wont cycle right
Sound like door/latch is not providing a secure door close anymore. Push on the door when the lights flash and see if this stops the blinking and continues with wash cycle. If it does, there is either somehing interfering withe the door closing fully, or the door latch on the door or dishwasher side is worn/defective.
Feb 22, 2009 | Kenmore Dishwashers
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Logo
188 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
