Question about Garmin StreetPilot c340 GPS Receiver
Screen The screen on my c340 will not stay on zoom. It reverts back to the original screen. Is there something wrong with my unit? Can this be corrected. Any suggestions would be appreciated.
  • 504 Answers
No, there is nothing wrong with your screen. The unit automatically zooms in and out depending on how far you are from where you need to make your next turn/change in direction. It cannot be "corrected", this is the way the unit is designed.
Posted on Feb 21, 2008
My apple iphone 3g is displaying in a zoomed mode need to revert back to original display mode can u help please
To fix this, tap on the screen using 3 fingers at the same time. That will zoom you out to normal screen size.
To turn off that feature, go to Settings>General>Accessibility> Turn OFF Zoom or any of the other stuff in there if you don't need it.
For more iPhone / iPad / iPod touch tips like jailbreaking and unlocking, CLICK HERE.
Apr 27, 2011 | Apple iPhone (16 GB) Smartphone
My I phone has a magnified screen and wont revert to it's correct size
did you just replace your screen?  If not, Simply doubletap with three fingers to return back to non zoomed mode.
Mar 14, 2010 | Apple iPhone Smartphone
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
Icons have got larger and dont fit on screen properly. When actioning a task briefly they revert to correct size. Was fitting a case and when finished everything was larger. Can,t see all keyboard or other...
The same thing has just happened to mine, I rang Apple helpline. Put three fingers onto the screen and double tap. This will reduce back to normal. Then go into Settings and choose accessibility and zoom. Turn this function off.
Nov 14, 2009 | Apple iPhone 3G
Iphone screen keeps zooming in
Go to (settings > general > Accessibility > Zoom) and click turn off zoom. Warning: getting around to just do this is a royal pain in the ***. Be patient.
Jul 19, 2009 | Apple iPhone 3GS Black (16 GB)
When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
May 24, 2009 | Balboa Instruments Duplex Digital Panel 2...
Zoom problem
The maker says it will go off by itself after 30 seconds.....If this is not the case see if there is a display button and turn display off,
I hope this is of help!
Jan 03, 2009 | Goodmans GCE5000 Portable DVD Player with...
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
GArmin c340
Facing the GPS system, remove the front cover with your nail or something sharp and under it you will find a reset button. If needed, refer to page 30 in this manual (different model but same principle, see website below) for pictures:
www.tramsoft.ch/downloads/garmin/streetpilot-c550_owners-manual.pdf
Please don’t forget to rate my answer.
Oct 11, 2007 | Garmin StreetPilot c340 GPS Receiver
Digital Camera Zoom problem
Charan, It could be caused of weak batteries or batteries bad conntacts. Good luck !
Jul 23, 2007 | Kodak EasyShare C340 Digital Camera
Garmin StreetPilot c340 GPS Receiver Logo
97 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
