Question about Dryers
Kenmore elite dryer no heat
Mod: 110.6496630,
I think access is in the back but I cant remove the panel please help.
Thanks
    Sergeant:
    Champion:
  • 291 Answers
You dont get into it from the back ,,, the lower panel on front comes down ,,,, clip about 2" in from both side between bottom panel and door panel needs to be pushed in to releast the panel and it drops down / larryyb
Posted on Dec 05, 2008
How can I get access to the thermal fuse in a
I believe tumble dryers have 3 thermostat fuses, they look like silver buttons, one on the back panel in the middle of the heating elliment, one in the ducting box for extraction and one somewhere else..I think.
tumble dryers are very empty inside, as long as its unplugged (I\'m an idiot.. 1 time) remove the back plate and have a look, if you need to unclip the wires inside to remove the panel, take photos so you know where they go back
Sep 23, 2014 | Dryers
My Kenmore elite electric dryer will not heat. I
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
How do I take off the back to get to elements and fuse on my kenmore elite dryer, I took screws off but the top appears to be welded.
Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
Mar 12, 2010 | Kenmore 62992 Electric Dryer
I have a kenmore elite dryer for about 4 years and it will not heat up. Can you please help?
check breakers in panel make sure both are in the on possition(home elec. panel)....if thats not it replace both heating elements...they are located on the back usually held in by 2 screws in each one..youll find these at lowes or home depot
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore gas dryer heats for several minutes ,then goes cold
I'm haveing the same problem with my frididaire gas dryer. I replaced the ignitor and cleaned the inside parts with a vacume and still having similar problems as yours. I think I will replace the temp. sensor that is attached to the flame tube inside the dryer next. To gain access to the inside parts you will need a putty knife to release the top panel. Just slide the putty knife along the top seam in front of the drryer. There are 2 clips that realease the top peice. With the top lifed up you will see 2 phillips head screws attaching the front panel to the dryer. Remove those screws and lift upwards and the front panel will lift right off the unit.carefully place the front panel to the side without damageing any wires attached. Then all your gas assembly parts will be visable in the bottom left cornner of the unit.
hope this helps,
Aug 23, 2009 | Kenmore Dryers
Dryer blows cold air but no heat
The heating element is in the back of the dryer. Sometimes there is a small access panel that will allow you to check the terminals to the heating element. You will need an ohm meter or multimeter to check.
Jan 02, 2009 | Kenmore 62802 Electric Dryer
Dryer not heating
what is the model #the heater is not in the back of the he4.
Oct 21, 2008 | Kenmore Elite HE4 Electric Dryer
How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition ..ck to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
Aug 29, 2008 | Kenmore 75962 Gas Dryer
Kenmore elite dryer
can you spin the drum by hand? if not,pull front panel off by removing three screws on bottom, remove lint screen, then remove three screws holding inlet housing ( the big brown thing in front) check to make sure not clogged with sock, panty hose ,bra underwire ,etc.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
41 people viewed this question
Top Dryers Experts
