Question about Zanussi ZCM900X Dual Fuel (Electric and Gas) Kitchen Range
Zanussi Oven Fan ''Ringing''
We have a Zanussi ZCM900X mixed fuel cooker (Gas hobs, electric oven) that came with our house.
When the fan kicks in, it lets out a loud "ring" until it switches off again.
Any quick remedies?
  • 333 Answers
Your fan blade is probably touching the metal shroud around it or the blade is loose. You can check this by gaining access to the fan and visually looking at it. Please do not do this with the unit plugged in, electricity kills. I hope this helps.
Posted on Nov 23, 2008
Hi We have a zanussi ZCE 7550 double oven cooker. The bottom oven broke (with a flash and bang), so we replaced the element at the back as it was burnt out. The top grill and hob are still...
Hello starsevern!! Did you get your cooker fixed, what was the problem?
I have a Zanussi ZCE7550, but apart from that I'm in exactly the same predicament as you in the post you made on Sep 18, 2010...
Can anyone help with a suggestion please???
Sep 18, 2010 | Zanussi ZDQ495 Electric Double Oven
Oven not heating up but fan working
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Aug 11, 2010 | Zanussi ZCM900X Dual Fuel (Electric and...
Zaunssi ZBF360X built in Oven Not Heating
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
I have a zanussi buit under double oven the main oven all the lights come on but no heat. it worked yesterday well top oven works and so does gas hob
If it is an electric oven and fan assisted, and the fan is working o/k, then you need to fit a new oven element, located behind plate at rear of oven.
Please rate my solution.
Thanks.
Nov 12, 2009 | Ovens
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Fan oven door, cooker surround and hob become burining hot when using fan oven
Sounds like a problem to me. Check your oven door gasket to make sure it's intact and also that the oven door is closing completely when this overheating occurs. Although some heat will rise, it shouldn't become "burning hot".
Mar 09, 2008 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Jan 23, 2008 | Creda C362E Electric Kitchen Range
OVEN PROBLEM
have you tested the element with a test meter /
Jan 07, 2008 | Zanussi ZCM900X Dual Fuel (Electric and...
Zanussi ZCM900X Dual Fuel (Electric and Gas) Kitchen Range Logo
260 people viewed this question
Top Zanussi Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
