Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
I have a feature on conv oven i dont understand what it is
On the conventional oven if you turn all the way up it has a feature i havent used before it is a click on the dial passed the highest temperature with a dotted symbol what does it do????
  • rutlandhairw Nov 23, 2008
    it doesnt tell you in instruction manual thanx so much
I think this is the dfrost function. It is on mine anyway.
Posted on Feb 23, 2011
  • 333 Answers
It is probably a self cleaning oven. If you turn your knob to this your oven will clean itself. I hope this will help you.
Posted on Nov 23, 2008
  • manucampbell Feb 23, 2011
    I think this is the 'defrost' function.
  • Frank Russo Feb 23, 2011
    The newer ones have this self cleaning feature that when it is in this position your oven door should lock because the temp gets do hot you could get burned. Do if your door locks that is what it does hope this helps .
What does coded F10 mean on my GE wall oven
This is likely a failed temperature sensor. The sensor is easy to replace but its behind the oven so you have to pull the oven out of the wall which isn't easy. This seems to happen when we use the self cleaning feature, its happened to us twice, havent used self clean since the second time we fixed it and its never happened again.
Nov 20, 2016 | GE Ovens
Need manual for Kenmore oven model#C970-648141
I am looking for a manual to a Kenmore Self-cleaning Convection Oven. I bought it used it has selection for conv bake, conv roast, bake or broil. According to the website, my model number doesn't exist -- really? Everything works perfectly - I just want to understand the difference between "bake" - "Conv bake" and "Conv Roast"
Mar 29, 2013 | Kenmore Kitchen Ranges
Model no. SA420X oven. Have rubbed off the pictures that show the choice of cooking eg. super fan forced or fan forced, conventional etc. I need to see a picturs of the dial as it isn't in the manual
I dont know if this helps but if you turn the dial to the different settings and leave if for 5 to 10 minutes between testing you should be able to figure out what does what. Conventional generally means no fan forced. Fan forced generally means fan with one to two elements. Super fan forced generally is fan with two to three elements. You should be able to see or feel most elements. Sometimes the one or two elements in the bottom are actually located beneath the oven floor.
Feb 06, 2011 | Smeg Ovens
Error code F5:E7 Can not get the oven door unlocked or reset this code. What do we do?
Beginner on forumn, don't have any manual in front of me on f5:e7. Sounds like a conventional oven problem, oven door locking. If in fact is some form of conventional heat oven (convection?), I had similar problem with a GE range, it flashed some kind of code seams like which I later interpreted by using owner's manual that explained codes. In my case it was in "cleaning mode" and you can't turn that off unless you unplug or turn breaker off, that puts it back to default mode with nothing running. I simply tried out the self cleaning feature, from there the oven went to full on heat and oven door locked unexpectedly. I learned stays locked till cycle finishes and oven cools, which is some time after the oven automatically switches off, said that it can be a couple of hours before you hear a...click, and now door opens (note to self, don't ever do that again).
Jan 13, 2011 | KitchenAid Microwave Ovens
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
LOWER OVEN DOESN'T HEAT WHEN FAN IS SELECTED
Hi Ginozzzz,
Sounds like it could be the Fan Oven Switch - especially when it works on the conventional oven. Does it have a separate element for the Fan Oven? If it is not the switch it could be the Fan Oven Element. Unfortunately I am not familiar with the oven so thats about the best I can do for you.
Regards
Bryan
May 26, 2008 | Ovens
Aman biult in oven
F2 is Oven sensor is out of range .. oven sensor is sending a reading that the control can not understand... replace oven sensor and you may have to replace the control too as it may not be reading correctly... good luck and let me know if it helps
Jan 02, 2008 | Amana AOCS3040 Electric Single Oven
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
187 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
