Question about Proscan PSVR73 VHS VCR
Cant play tape
We cant seam to make the tape stay in the recorder all the time and play.at certin times it will pop out the tape and refuse to play it.is there a timer on these things? ours is a proscan plus silver ser.#02327006 cant find modle # and the book came in all spanish.
  • 883 Answers
The end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Posted on May 20, 2007
How to record live sounds
Plug a monitoring headphone into the monitor socket and try to record if the sounds that you try to record with is working. With an oscilloscope check the recording head is there a sine wave signal if not then the oscillator is kaput record switch operating correctly?what is the age of the tape itself? Was it played back a lot of times? I found this when some tapes refuse to take other recordings when used a lot
It is difficult to say what went wrong if you do not have access to the unit
May 28, 2013 | Technics RS-TR575 Single Dual Cassette...
Got the Tape2USB for christmas and cannot get it to successfully record to computer. Followed installation directions closely. When I want to record, I press [on Tape2USB] 'Play'. Then, I press [on MAC]...
I'm not familliar with this device but from the ERROR it spits out you seam to have a configuration problem, since it is a TAPE wich is 44 Khz SAMPLE RATE, check the sampling rate settings it might be to high or to low
Hope this helps!
Dec 31, 2010 | Grace Digital Tape 2 USB Dual Cassette...
Every time i put a tape in to play or record, it keeps ejecting it why??
Please be more specific. When you insert tape, the tape housing extract to its body, or it just stays still and eject your tape.
Aug 15, 2010 | Canon ZR100 Mini DV Digital Camcorder
Cassette ejection mechanism not working
pull the player and have it repaired, sounds like the belt is no good for the tape drive loading mechanism.
Apr 13, 2009 | 1999 Ford Taurus
JVC GR-D350U problems
I have seen this many times, and it is usually always dirty heads, and it is a bigger problem when you record in long play. If the heads were dirty when the tape was recorded, then that is how the image was stored and will stay that way. So make sure you clean the heads before an important recording. Try cleaning them again with a new cleaning tape, and it just might come good if it was originally recorded fine.
Sep 20, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Incompatible Tape
try a cleaning tape first - best not to rewind the cleaning tape because it will put back the crud previously removed ? into your heads and guides ( last tape to play is prime suspect ) ; - - digital heads wear faster than analog so a new set of heads is next possibility but if the cleaning tape works . . . retire your library soon as possible .
Jul 26, 2007 | Panasonic PV-DV400 Mini DV Digital...
Time Date Stamp on finished Video
the time and code is recorded all the time but the only way to put it on the display is to use the remote control. when plyback a tape press the time/code button(i think this is the right name of the button)on the remote. this camcorder has a different way to display the time than other cams and you have to do this every time you play something(feature does not stay on after shutting down the cam or ejecting tape)
Jul 18, 2007 | Sony Handycam DCR-TRV130 Digital Camcorder
Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Aug 10, 2006 | Sony Handycam CCD-TRV108 Camcorder
Televison & Video Logo
101 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
