Question about HP Office Equipment & Supplies
What connection do I need for my photosmart 360 series printer to print pictures from my computer photos?
    Guru:
  • 1,342 Answers
Most likely a USB A-B cable like this one. CLICK HERE
Check your printer to make sure the connector matches the one on the cable. The other end will go into an empty USB port on your PC.
Posted on Nov 23, 2008
How do I print photos from my cd using hp Photosmart plus?
Don't Connect the printer. First use the cd to install the software for your printer. in the software is a program called print photos or print pictures. After installing the software, connect the printer and switch it on. Start the software and a menus should guide you trough he straps to choose and print the pictures you want to print. Be aware you need to setup things once the program is running, like how big the pictures should be. Don't make them bigger than the paper you insert. Also what kind of paper you use, like plane paper, or photo paper, matte or glossy.
Mar 20, 2015 | HP Photosmart Plus All In One Printer b210
HP photosmart 8100 will not print from photo tray of picture online, only main tray. IT WILL PRINT from photo tray when I print selected photos from a camera card, so problem is not with the tray or...
It probably don't support that function via the internet... or it may just be a setting your missing by default its not going to use the more expensive paper for internet printing although for a camera card it would because odds are your printing pictures from a Camera Card.... so in short no you didn't mess anything up its just a matter of settings or worst case put the internet photo on the camera stick and print it that way...TAA DAA
Oct 10, 2013 | HP Photosmart 8100 Series
I just bought an HP Photosmart Premium e-all--in-one C410 series printer/fax/copier. The problem is, I'm unable to print photos using the photo tray. There's no option to select photo tray like my...
The problem is in your printer set up. When you go to print, select the type of paper, size, horizontal or vertical print mode. If you do not designate photo with size and paper type; it defaults to standard 8x10 paper from the lower tray. This is all explained in your printer manual or on line at HP.com.
Feb 01, 2018 | HP Photosmart C4100 series
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
Ink not printing the same image quality that is on computer
Issue When printing directly from a memory card, the printouts have an abnormally high red tone.
NOTE: This does not affect the prints that were originally sent from the computer. Solution Press the Photo Fix button to turn off the Photo Fix feature before printing from a memory card. Cause The Photo Fix feature was originally designed to reduce/enhance printed pictures by making colors more vibrant. However, it can also have a side-effect to make some prints have more red tone than desired. In the HP Photosmart D7100 series printer, this feature is “ON” by default.
Dec 15, 2008 | HP Photosmart D7160 InkJet Printer
I have just installed my C5580 printer and every step was perfect. I printed a picture from my library- no problem. I inserted my camera memory card and printed a picture - no problem. Then I went back to...
what PC, HP, then what HP model
what OS< what operating system. on that PC.
did install the C5580 software, packing from HP.com
matching your OS?,
how is the 5580 connected to that PC.
USB connected?
Or blu-tooth connected.\
the manual.
http://h10032.www1.hp.com/ctg/Manual/c01507549
the software is here.
XP throught a w10 software is here, match what you have.
https://support.hp.com/us-en/drivers/selfservice/hp-photosmart-c5500-all-in-one-printer-series/3575176/model/3575255
if running XP, make sure SP3 is installed, service pack3
if USB fails try different USB port on that PC.
Apr 26, 2017 | HP Computers & Internet
HP Photosmart C3180
Do you know if that control panel in you computer for that printer needs to be told that you are printing pictures?
Some models you do by selecting photo paper.
Jul 05, 2008 | HP Photosmart C3180 All-In-One InkJet...
Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
Oct 15, 2007 | OKI C5200n Laser Printer
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
