Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Drip pan wher can i bay the removepel drip pan for my spectra the corners are not the same it has a right and left side
  • 333 Answers
You can buy this pan at your local appliance parts store. All you need is your model and serial number.I hope this helps you.
Posted on Nov 23, 2008
I have a leak from the bottom of my freezer. IT seems to be coming from the front left edge corner. Dripping down the adjustment screw leg. I just cleared drain line so its not that again. This is ano
That's where the drip pan is for the underside models, other than that it's likely a leaky door seal on that side or the case heater went out letting it sweat.
Apr 01, 2014 | Admiral 26 cu. ft. Side-By-Side...
Drip pan
The drip pan is located behind the toe panel (grille) at the bottom. The pan should be located in the left side. If you have auto defrost, the pan may or may not have water in it. It is likely to have accumulated grunge which can be removed by a good wash and rinse, being careful to avoid breaking the pan during cleaning. Reinstallation is the reverse of removal.
Sep 12, 2012 | Maytag MZD2766GES Side by Side...
WHERE IS THE FUSE FOR THE RADIO
it should either be in 3 places under left or right side dash fuse box , left or right top corners of your engine bay, or when you open your door there should be a panel on driver or passenger side closest to the hinge on the door
May 04, 2012 | Dodge Ram 1500 Cars & Trucks
The drain pan under my refrigerator stinks really bad how can i remove it to clean it
The drain pan can be removed by lifting up the refrigerator and removing the four torex screws on the bottom of each side of the refrigerator. Use 2 pieces of 2x4 to hold up each side of the fridge while removing these screws. After removing the screws the bottom panel will separate from the refrigerator and you can remove the drip pan from the panel as it isn't attached by screws. The pan is VERY fragile and removing the drip pan is a two person job. I recommend just pouring bleach into the drip pan to kill any bacteria causing the smell by removing the back panel which will be held on by several quarter inch screws. You'll see the white drip pan on the right hand side of the fridge looking from the back.
Aug 06, 2011 | Refrigerators
Wher isthe drain plug for engine oil on 2009 dyna super glide
The engine oil is carried in a pan underneath the transmission. The plug to drain the oil is also underneath the transmission. It's usually the plug that is the on the left front corner of the pan.
Good Luck
'Steve
May 11, 2011 | Harley Davidson FXD - FXDI Dyna Super...
Water leaking from base of unit during operation
dehumidification is something that AC units do as a by-product of cooling so yes, it is acting as a dehumidifier. there is a coil (copper tubing snaking back and forth through metal fins like on a radiator) that water condenses on and drips off of. That water will fall in to a pan and then will either evaporate or run through a drain. Make sure the path from the coil to the drain pan is clear. The water will either drip down (pan sloped to a corner or hole) or run through a tube to the drain pan. The drain pan is the part that had the drain plug in it. If that pan was dry the condensate is reaching the pan. If it is full that means either the drain is plugged up or the unit is pulling humidity out of the air faster than it can evaporate. Check to make sure any drain tube is clear and that the path for the condensate (water) is sloped the right way - not shaken loose or tipped to the wrong side.
That should get you started. Let me know if I can be of any other help.
Good Luck!
May 26, 2010 | Haier HPC07XC6 Portable Air Conditioner
Terrible smell coming from bottom of unit
There Should Be A Grill On The Front Bottom Below The Door. Remove That And It Should Come Out Of The Right Side.
Jan 05, 2009 | Maytag MSD2656G Side by Side Refrigerator
GE refrigerator tfx27zp or 25zp or 22zp not sure.
The drip pan is located under the front of the frig.
FIX
open both doors, remove the panel that is across the bottom of the fridge( there are release tabs over the left and right front corner areas close to the hing sides
after removing the panel you should see a tray that slides on rails under the fridge
remove the panel and inspect to see (use a flash light)if you can see the drain tube
I believe your drain tube is freezing up somewhere inside the frig
If you can determine where this drain tube fishes up through the back inside wall of the frig
remove all of the trays and observe the back panels there should be some type of collector tray
near the frig light Some models have a hot bulb to do the defrost
I suggest that you tun frig off with both doors open take a hair dryer and blow hot air where you think the drain is located to melt any ice and look down in the drain pan to see if it starts draining
Hope this helps
Good luck ( ps cal ge customer service and give model number I bet they have a design poblem
If they do they may have a work around
God Luck
Jan 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge Leaking water from front right hand corner
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
Oct 19, 2006 | AEG SK78800I Compact Refrigerator
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
184 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
