Question about Refrigerators
I have a moffat stove and it keeps shutting off on me. The door lock light comes on then the oven shuts off. Does anyone know how to fix the door lock.
  • deni8828 Nov 24, 2008
    I seem to have the same problem. Has it got something to do with the timer? First the light was working, then nothing, but not fused. Then the oven would not switch on. This is a Moffat Comtessa Digital. Help!
  • deni8828 Nov 26, 2008
    I have more or less the same problem. I think it has something to do with the timer/clock? Getting quite desperate. Mine is a Contessa Digimatic and the model number on the stove is not listed anywhere on any of the Moffat sites I can find!!
    Denise
  • 833 Answers
SOURCE: GE Spectra JGBP85
Try this: turn off the circuit breaker to the oven. You are looking for a pair of breakers generally rated 40 amperes or more. Turn them off, wait a minute and turn them on. If that doesn't do it, then there may be a circuit board issue.
Posted on Dec 13, 2007
  • 1314 Answers
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Posted on Jun 05, 2008
jyackle5
  • 8197 Answers
Sounds like you bent the door where the lock is. You might have to replace the door.
Posted on Mar 12, 2009
  • 89 Answers
SOURCE: STOVES 600 oven door wont shut properly
open the door about 30 degrees, lift straight up to release the hinges, this will allow you to remove the door.
you will be able to assess the hinges from there.
most likely the hinges are just out of alignment
Posted on May 26, 2009
SOURCE: Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Posted on Jun 11, 2009
Oven will not come on error message F31 appears
the oven needs two things 1, gas or electricity plus 2, thermocouple.
If gas try lighting manually by removing oven bottom plate of oven when possible. That puts everything out in the open. If it does not open that way go to the bottom broiler opening and light manually.
this will tell you where the problem is.
Electric oven, go to fuse box and shut off supply line them turn back o n. This is easiest fix and resets the stove. On electric stove there may be an interlock that shuts oven off when the door is open.
Hope this gets you started!!!
Apr 04, 2016 | Kitchen Ranges
Ignis AKL828 door hinges locked in shut position... door off oven!
Take a pair of pliers and pull the hinge out of the socket. This will take care of it. After doing this, then simply set te door back in place and shut.
Mar 06, 2013 | Ovens
1952 Moffat Bake Stove
I have a working 1952 moffat stove with warming oven if interested
Oct 27, 2009 | Kitchen Ranges
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
Lock light is on and do not know how to get it off
hi there,
the light is on because the door is not shutting correctly. check the door lock mechanism or the door gasket and make sure the the door is on its hinges. the door should go out.
if this still doesn't solve the problem, it's the light socket itself. i would recommend to have it replaced.
Jul 16, 2008 | Maytag CWG3100A Gas Single Oven
Self cleaning won't shut off
that is because it needs to cool down before the oven will unlock.There should be a timer running and when it gets to "zero" it should unlock.
Jul 08, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Door
I have spilt water inside the glass of my Fridgaire stove and wondering how to take the glass off the front so I can clean inside it.
Jun 02, 2008 | Ovens
Refrigerators Logo
239 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
