Question about Sentry Fireproof Safe
Cannot close msw3517 safe using the 5 digit electrionic code The handle is in the down positiom and it wont move either way - up or down.
  • mgzdwl Nov 26, 2008
    The safe was fixed after several days, a couple e-mails, plus several experts..
5 Suggested Answers
  • 9 Answers
SOURCE: sentury safe Model MSW3517
go to this website.....
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
if no help from there its worth the $12 to ask for their help, because having a safe is def. worth $12.
Posted on Feb 08, 2008
SOURCE: sentry safe msw3517
I have a Sentry Safe MSW3517 and forgot my code.
Posted on Nov 19, 2008
  • 76 Answers
SOURCE: MSW3517 Book inside
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number.
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
Posted on Apr 28, 2009
  • 8457 Answers
SOURCE: I have a Sentry Safe MSW3517 and can't remember
Not possible only u can do it with the dustruction of the combination lock pad.U ever register this safe?Yes?U can call the company up they'll tell u ur combination,because it a requirement,when u register it or they'll sent some one out for there master secret combination they get it open for u.
Posted on Aug 06, 2011
I have bought a used red head safe. It's open but I can't get it to close. Also, I don't have a combination for it and I'd like to make up my own. Can you help me?
Most likely it will not close because the lock has been activated while the door was open. Probably need to take it to a locksmith.
Jan 03, 2017 | Home Security
Sentry safe msw3517 ba139535* I need a master code for this safe it was my dad's he passed away
sorry but you will need a locksmith to access the safe their are no master codes you can also notify sentry for assistance
Oct 16, 2016 | Home Security
My elderly mum has a Kingavon safe 25. The locking bars are stuck out & it will not close. Inputting code changes nothing. Key lost. Is there anything we can do?
kingavon safe 25 instructions Safes Questions & Answers ...
www.fixya.com > Forum > Tags > kingavon safe 25 instructions
Kingavon safe 25 instructions questions and answers. ... head screw drive to the upper black handle plate n pop it out safe will open... when done put bar back in and safe ...My Sentry 3150 safe is closed and locked and the lock/dial is stuck.
How to crack a safe without any tools?! - YouTube
? 5:46
https://www.youtube.com/watch?v=hcYB9ceiAiY
Oct 19, 2011 - Uploaded by mepickulongtime
Detailed guide on how to open a digital safe. ... Can you use a magnet to move that spring down that the digital lock controls? ...I don't think so since the safe is made out of metal and it wouldstick to the safe but have little ...
Nov 24, 2015 | Locks & Locksmithing
How does the safe lock
Generally, In these kind of safes you follow this procedure.
1. Punch in your code.
2. Press the # button.
3. Safe gives a beep sound.
4. Turn the handle to lock position.
5. To open also similar procedure to be followed.
Jul 15, 2014 | Safe International Digital Electronic Safe...
Aug 06, 2011 | Safe International Sentrysafe Security...
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
I need mastercode to open sentry safe msw3517
we have forgotten the code and cant find the keys . it has a number on the bottom esb 3c3480084406
Feb 11, 2010 | Sentry Fireproof Safe
Lost my combo to my MSW3517 safe
yes you can
http://www.sentrysafe.com
mj
Feb 22, 2009 | Sentry Fireproof Safe
Sentry safe msw3517
Mar 16, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
280 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
