Question about Panasonic Workio DP-2500E Copier
How to set the paper size in the trays?
The copier shows only A3 for both trays. One tray isnt A3, but is filled with A4. So it says there is no A4 tray available and I can´t print or copy in A4. Is there a possibility to change the paper size of the trays or is it set automatically by the copier sensors?
Thanks a lot!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
Most are set by the trays itself, when you adjust the "guides" that go against the paper it adjust some levers on the side or back of the tray which push on some sensors behind the tray.
Some however you need to turn a dial in the tray to the paper size you need.
make sure the guides are snug against the paper, the dial or settings are correct and that there is no paper behind the tray.
Also I'm not sure what country you are from but in the US we do not use A4
Posted on Nov 24, 2008
Special paper tray is empty error
Sounds like someone requested A4 size paper in a print job instead of the normal Letter size paper...
Try putting regular letter size paper in the bypass tray and then set it up as A4 size...the print job should then print out on that paper.
Apr 09, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
I need to change our Canon IR2016 from A4 to A3, Also I need to activate 1 to double sided copies. I am looking on line for the user manual for the IR2016 but can't find
ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
Jan 19, 2011 | Office Equipment & Supplies
E-Studio 3511 will not print a3
check to make sure on the display panel the paper tray is showing A3 PAPER SIZE>> the paper size indication should match up to what is in the trays if not the machine will be asking for A3. Also try putting in another tray to see if there is a fault with the paper tray .. if it works with other paper sizes it may just be the size hasnt been set properly for that tray.. Hope this helps A
Jan 18, 2010 | Toshiba E-Studio 3511 Color Copier
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Apr 08, 2009 | Konica Minolta DiALTA Di200 Copier
How do i set paper sizes on my canon ir2016i printer
Open the paper drawer
Remove the paper
There is a blue paper size plate,that keep the paper in the correct posision,Push it to the front and downwarts.The paper plate should come loose from the tray.Put it back in the openning for the A4.The openning for the A4 papersize is mark inside the paper tray.
Now set the blue papersize dail to A4 paper .
Then you are ready to copy with A4 paper.
Feb 19, 2009 | Canon iR 2016i Black and White Copier
Paper size
The problem is with the printer side. there is option in the printer, Set manualy paper size from the printer paper tray. I think this will help you.Goodluck.
Mar 10, 2008 | HP LaserJet 5550DN/EN Printer
A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Oct 02, 2007 | Sharp AR-161 Laser Printer
Panasonic Workio DP-2500E Copier Logo
246 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
