Question about Leica D-lux 3 Digital Camera
Button stuck, casuing unrepsonsiveness in all other buttons
Hi, I have a Leica D-Lux 3. Recently I as shooting pictures throughout the day. I switched the camera off and then back on at one point and none of the buttons were working (I couldn't scroll through pictures I'd taken or even press the shutter to take a picture).
Everything else is fine, I can see the LCD display, change the ratio of the picture, change the focus, go onto different modes. I discovered that when I went to the 'scene selection' mode on the camera (where you can choose different presets like sport mode, landscape mode etc) that the menu was constantly being scrolled up like the up button was being held down.
I found that holding the down button, stopped the scrolling, but didn't actually scroll down and I still couldn't get the functions of any other buttons to work and I think that the problem is the computer is constantly being loaded with the functions of the 'up' button so can't process anything else. Does anyone know a solution to this problem?
I haven't found a camera repair shop in the area I am in at the moment, but do you think it's something that can be fixed without sending it away for repair?
  • b3nfather Nov 25, 2008
    Ok thanks for the advice. I will try using the alcoholic que tip tonight and give it a clean, though I don't feel too comftable doing this it's worth a try. I do remember however that when I had the casing of the camera off and the rubber pad was sepeated from the circuit board, I tried switching the camera on and the problem with the still occured, behaving as if the 'up' button was still being pressed.
    Questions I have about it - Is it possible that particles on the other side of the circuit board may be causing the problem? If so would removing the circuit board be advised to clean the other side?
    Also would trying to take the internal battery out be recommended to maybe try and reset the circuit board? (Though it doesn't look like it can come out too easily)
    Many Thanks.
  • b3nfather Dec 20, 2008
    I have my camera fixed now :) I had to send it off to Leica for a service. They gave me a great repair service, doing it under garuentee, returning it promptly and very securely packaged as well. On the invoice it says that the zoom switch was replaced and so I believe this is the soltuion to this problem.
  • 579 Answers
Most buttons on a camera are a simple raised rubber pad over a printed circuit board. The button gets pressed, a concuctive material on the bottom of the rubber pad puts a short across a printed pad. If the camera senses a short across the down button, it will ignore all other buttons. You need to take the back off the camera and the rubber button pad will probably be right in the back, clean the contact with an alcohol Qtip and you should be OK.
Posted on Nov 23, 2008
  • Steven Wander
    Steven Wander Nov 25, 2008
    not likely, as PCB's are usually 2 or more layers thick. the backside is a totally different board circuit. If cleaning doesnt stop the "out of control" up button, then removing the onboard battery (its a capacitor I beleive and is usually soldered in, not socketed) might help, but leaving the batteries out for a week will do the same thing. You could hasten this by discharging the capacitor with a resistor across the + and ground of the camera. Is there a recessed reset button on the bottom (like all SONY's) I would try that first. If cleaning doesnt help, seek professional help. Good luck, Leica's are worth fixing. If cost prohibitive, drop me a line. Steve.
Dell desktop about a year old does not recognize SD 4 GB pictures from my Leica D-Lux 3.
Your 4GB card is an SDHC card. Is your card reader compatible with SDHC cards, or only with SD cards (2GB or smaller)?
Sep 19, 2013 | Leica D-lux 3 Digital Camera
Tip
Leica V-Lux 30 1080i AVCHD MTS/M2TS Footage to iMovie Conversion with Apple...
Leica V-Lux 30 AVCHD to AIC for iMovie/FCE Native Editing on Mac <br />Leica 1080i HD videos to iMovie or FCE in Best Quality <br /><br />Nowadays, a simple device with multiple functions will make the digital life easier, and many people enjoy the convenience. Leica V-Lux 30 is one of the compact point-and-shot V-Lux series for taking photos and videos during the travel. With this great travel companion, you can use the GPS tagging function to mark location of your images and videos. <br /><br />If you face problem importing the 1080i video to iMovie or FCE, you may try to <b><a href="http://www.aunsoft.com/final-mate-mac/">convert AVCHD to AIC</a></b> (Apple InterMediate Codec) for native editing on Mac. Aunsoft Final Mate for Mac is the best choice for you to get HD videos with less compression, keeping best quality. It is as easy as 1, 2, 3. <br /><br /><b>1. Import Leica 1080i videos to Aunsoft Final Mate for Mac.</b> <br />Run Aunsoft Final Mate for Mac, and connect Leica V-Lux 30 to iMac via USB cable. When the camera is connected, you will face a pop-up window as camera wizard from Final Mate for Mac. Just follow the instruction to download videos to Final Mate for Mac. If you have ready download the videos from camera to computer hard drive, Final Mate for Mac would also recognize the .mts, .m2ts files, if you go to the Resource tab and add the file path which contains the mts/m2ts files. <br /><br /><b>2. Select AVCHD footage for converting to AIC.</b> <br />Click on the files you would like to convert to AIC, drag and drop to the Movies tab. You can create a single movie for each file, or join multiple files into one to get separated files or one joined file from the <b><a href="http://www.aunsoft.com/final-mate-mac/">MTS/M2TS footage to AIC conversion</a></b> by Final Mate for Mac. <br /><br /><b>3. Export AIC for iMovie and Final Cut Express.</b> <br />Click the Export button on the tog-right corner of the timeline section, and go to the 3rd button. Choose iMovie and Final Cut Express &gt; Apple Intermedidate Codec(AIC) (*.mov) as output format. Choose 1920x1080 as output video resolution, then click OK to start conversion. <br /> <br />Wait for the conversion and then import the <b><a href="http://prores-converter.com/2011/06/leica-v-lux-30-avchd-to-aic-for-imoviefce-native-editing-on-mac/">Leica HD videos to iMovie or FCE</a></b> without rendering. <br /><br /><b>Tips:</b> <br />1. You can also tick the checkbox for Deinterlace to make the interlaced 1080i video to progressive mode without obvious lines. <br /><br />2. It is said that Aunsoft Final Mate for Mac and the related Aunsoft products work on the pre-release version of Mac OS X Lion v10.7. So it should also work even if you update your Mac to Lion.
on Jun 24, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Recently I bought Leica D-Lux 5 Digital Camera on Creaiglist. It does not have stickers on the bottom of the camera and I don't know the serial number too. How can I get necessary stickers to stic
Each camera made has it's own serial number so the manufacture can track the item for warranty service, it is impossible to obtain stickers for that reason.
Jul 23, 2012 | Leica D-Lux 5 Digital Camera
Leica c lux 3 system error (zoom) Zoom is stuck.
i read the manual, and they recommend bringing it to a service center, after turning it on and off. Sometimes sand gets stuck in the lens, or sometimes the internal button cell battery goes dead which would disable the zoom. If you feel confident in your component abilities, crack it open and replace that battery.
Apr 06, 2011 | Leica C-LUX 3 Digital Camera
I am getting blurred pictures in flash obviously somthing wrong with the syncronization setting but cannot find out how to alter it??
You may have the flash set to slow shutter sync. Press the flash button (the one with the lightning bolt) and watch the screen for a bolt and an "A" or "auto".
Feb 08, 2010 | Leica D-lux 3 Digital Camera
Can't find instruction manual
Hello
At the link beow you will be able to download the manual for the requested manual.
http://www.retrevo.com/support/Leica-D-Lux-3-Digital-Cameras-manual/id/522dj983/t/2/
Kind regards
Andrea
Jan 24, 2010 | Leica D-lux 3 Digital Camera
Leica d lux 3 LCD was shattered (by TSA). Can I
Google the words...disassemble a digital camera. Go to some of the sites and then make up your mind.
Nov 20, 2009 | Leica D-lux 3 Digital Camera
Leica d-lux 3
My Leica V-Lux 1 camera has washed out pictures in Auto Mode,and also in the other Modes. How do I set camera to get good quality stills?
Jul 21, 2008 | Leica V-LUX 1 Digital Camera
Leica D-lux 3 Digital Camera Logo
179 people viewed this question
Top Leica Cameras Experts
Steve
Are you a Leica Camera Expert? Answer questions, earn points and help others
