Question about Dell XPS™ 600 PC Desktop
Added more ram from 2gb to 8gb but still say only 2gb
Addedd match pairs of 2gb ram cards to xps 600 for a total of 8, pc had only 4 match pairs of 512mb for a total of 2gb to start with. when i rebooted pc it say to hit F1 for ram update wich i did and after checking it only showed a total of 2gb. i checked cards and they are in the slots all the way. if any body has any input on this i would like to hear it.
  • s_griffey Nov 23, 2008
    should have checked that before i made the change,thanks again
  • rfshaw194 Dec 24, 2008
    Same problem. I upgraded from four 512MB DIMMs to four 1GB DIMMs. The BIOS recognizes 4GB, but Windows XP only recognizes 2GB. drlalitv's answer indicates s_griffey should have shown at least 4 of the 8GB he installed.
  • 488 Answers
added more ram from 2gb to 8gb but still say only  - 1fb3933.jpg the above will help u..the OS will not support the RAM you have hence its not showing..hope it heps!
Posted on Nov 23, 2008
My pc keeps hanging when i install an additional ram which is 4gb my current ram is 2gb My specs is: Intel Core i3 530 2.93GHz 2GB RAM 2GB Palit GeForce GT 610 1TB HDD Windows 8 Pro 64-bit Asus...
what clock speed is $are 2gb Cards. You should use 2 2gb cards rather than 4 1GB cards. If you can boot up down load Belarc Advisor and run identify particulars. It's free.
Sep 03, 2013 | Gateway Dx4831-01e Intel Core I3-530 2.93...
Vram is 256 mb but dedicated is 64 mb and shared is 192mb . how do i change it.. no option in bios also. Sony vgn n220e
You should not change this. Laptops have small video chips and often depend on "shared" memory to achieve good performance without overheating. Basically, the video processor borrows some of your installed RAM memory. Also, your laptop may have been supplied to you with less total RAM memory than the maximum and you can add more memory. In Windows, click on Start then right-click on Computer and select Properties. In the Properties window you can read how much total memory is installed. 2GB (2048MB) is a desrirable amount for Windows XP. Windows Vista and Windows 7 can benefit by having total 4GB of RAM memory. Check your Sony user manual for instructions on adding more memory. Basically, you turn off the laptop, remove the battery pack and unscrew a small cover on the bottom of the laptop to access the memory slots. Usually, there are 2 slots here. Ideally, you should install a matched pair of memory modules (a "kit") for peak performance. However, quantity of memory is more important than having matched modules, so if one slot is occupied and the other slot is empty you may simply buy one more module and install it in the empty slot.
Aug 13, 2013 | Sony VAIO VGN-N220E/W Notebook
Ram cards
Make sure that when you populate the memory slots that you are using like memory cards per memory bank set. Example: A1 and A2 consist of one blue and one beige slot. Use a 2GB card in one and a 2GB card in the next one. Starting with A1, use your 2GB memory cards first and then the 1GB cards. Once complete, reboot your system and enter into the BIOS to verify the total 12GB are being "seen" by the system.
Also, consider your os. If you are running Windows Vista 64 bit, Windows 7... they will only see 8GB max. OS like Windows server xxxx will be able to see all memory avaliable to the unit.
Good Luck
C2S
Dec 19, 2011 | Intel S5000PSL (0735858182874) Server
There is 2 things i want to upgrade but i don't know what to get. I want to upgrade the graphics card, and the ram. Can you please give me some options? :)
First off I gotta say,bad computer case to work with(Not much room).If you plan on gaming and putting your graphics on high on every game then you might want to consider a new case cause good graphics cards wont fit but I have found some that do and they play every game til this day but I have to adjust some of the settings.I chose the EVGA GeForce GTS 450, and the EVGA GEFORCE GTX 260 hense I have two of this hellions!Both graphics cards I would say are about even now that I am running 8GB(4x2GB RAM),I just added 2 2GB ram sticks seeing as how you can only run 8GB on this motherboard and it already comes with 2 2GB ram sticks not sure of the brand they use but they work with the low profile ram sticks located here ---->http://www.newegg.com/Product/Product.aspx?Item=N82E16820231253 <----The cool part is they will replace them if they ever stop working for whatever reason!If I were you I would get these pair on the link I showed you and either of those graphics cards and I guarantee you wont feel let down,trust me,I was just gonna start all over with all new stuff before I realized that for like $50-150 I could have reliable computing,networking etc. plus Great gaming quality with the new DirectX11 pc games of today!NewEgg.com also has hand on videos you can watch that will show/teach you how to do it all your self!I hope this helps,good luck! -CB
Jul 24, 2011 | Acer Black AX3400G-U4802 Desktop PC with...
Dell precision 670. Adding 8 gb total memory. Using Kingston KX1563-NAB; DDR2 2gb 2Rx4 PC3200 EEC, registered. Accepts 4 gb in dimms 1 and 2 (2 gb modules) and boots fine. Adding 4 more gb in dimms 3...
glenn_mullin
From what I can tell the Dell Precision Workstation 670 does support over 4GB of RAM. However when you have over 4GB of RAM installed in the system you have to have the Memory Cooling Shroud connected to keep the memory cool. Also this is only shipped out when the system is ordered with over 4GB of RAM originally. If you do not have this part you can order it from Dell buy calling 877-671-3355.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 27, 2011 | Dell Precision Workstation 670 PC Desktop
What is the max ram speed my pc can take
According to some research, your desktop has 4 RAM slots available. The total maximum RAM your desktop can hold is 2GB (2048MB). Furthermore, each slot can hold a maximum of 1GB (1024) but cannot exceed the 2GB total.
This means you can theoretically install 2 x 1GB RAM DIMMS in 2 RAM slots or 4 x 512MB RAM DIMMS. Both will meet the desktops 2GB limitation.
The RAM specifications for your desktop are as follows:
RAM Limit: 2GB (2048MB) RAM Slot Type: SO-DIMM RAM Type: DDR1 (not DDR2 or DDR3) RAM Speed: PC3200/DDR400 ECC Type: Non-ECC
TIP: The RAM is DDR which means that while you can install them as singles (single-channel mode), the system will see a speed benefit from installing them as matched pairs (dual-channel mode).
Aug 14, 2010 | Sony VAIO VGC-RB34G PC Desktop
Want to upgrade memory to 2 GB. Desktop will not post up with 2x1GB cards. Every 2-3 seconds it makes a sound/tone. The fans would turn on but there is no signal to the monitor. However, it will post up...
There is no reset just because you added memory.
If you have 2- 1GB sticks, try both , one at a time.
Your system spec's and manual tell nothing which dimm banks are suppose to be used , and if you can install 2-1GB sticks,
all it says is it can handle 2GB.
Now it says 512MB, sticks, this could mean you can only use 4-512MB sticks to get too 2GB,.
Now it does not tell which dimms are used if you have 2-1GB sticks,
You have 4 slots, the first two and the second two, most times, you either use the second bank of each pair, or the first slot of each pair,
but as I said, your system does not say.
So you can try both ways and see if one of them work.
Sorry I can't be of more help,but you system has a poor manual
on memory placement.
Feb 14, 2010 | E-Machines T3302 PC Desktop
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
Multimedia audio controller exclamation sign
try this driver
http://www.drivershq.com/Drivers/VistaDevices/DELL-Audio-Realtek-ALC850-AC97-AUDIO-Driver/4342/Drivers.aspx
or
http://drivers.softpedia.com/progDownload/Dell-XPS-600-Audio-Driver-Download-40848.html
or try all these dell audio drivers from here
http://www.drivershq.com/VistaDrivers.aspx
or buy a vista compatible sound card
Feb 24, 2009 | Dell OptiPlex GX270 PC Desktop
8GB G.Skill F2-8500CL5D-4GBPK in Gigabyte GA-P35-DS3L rev. 2.0
If they are not a matched pair it will not work. If you have two sets of matched pairs. Each pair will have to go into the right pairing slot. Example one set you go in slots 0 and 2 and the other in slots 1 and 3. If you have stickers on the memory sticks look for a group of numbers and letters one group will match it's mate.
Apr 03, 2008 | Computers & Internet
Dell XPS™ 600 PC Desktop Logo
144 people viewed this question
Alun Cox
