Question about Radio Shack Pro-96 Scanner
PRO 96 Scanner
Main screen has message that states "all" channels locked out! I have done everything that manual said do and still get the same message. This is my first experience with a scanner of this quality and no doubt I am scanner illiterate. Detailed info on how to solve this would be greatly appreciated. Thank you
  • Anonymous May 06, 2008
    My PRO-96 Scanner now reads ALL Channels Locked out! I think I read the manual and even pushed the reset button on the side and can't get the scanner to work again. Also, when it was scanning all 10 channels on the top, it seemed to skip over number 4 and 5.
    My email address is ken32851@aol.com it that helps
I had the same problem. I called Radio Shack and they said there were no channels were programed to scan. I am very new at this so I would be able to help you program but call Radio Shack at 18008437422 and hit option 2 twice. The person I got on the phone was great. Just be sure to have the numbers you want to program in front of you.
Posted on Feb 16, 2007
2 Suggested Answers
SOURCE: all channels locked out
Is the Attenuation set to Global on? That may be the issue.
Posted on Aug 01, 2008
My pro 96 says all channels lkocked out
Here is a link to the users manual in PDF Since I don't know if you are locked out of one channel of locked out of a band this manual will get you back to trunking in no time.
http://support.radioshack.com/support_electronics/doc71/71778.pdf
Mar 15, 2011 | Radio Shack Pro-96 Scanner
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
When scanner is turned on it says all channels are locked radio s
If this is a trunking scanner, then you can go to your local radio shack store and have them reprogram the scanner with your local frequencies. This does sometimes occur if the trunking is not set correctly.
luthierrick@yahoo.com
Jan 24, 2010 | Radio Shack Pro-96 Scanner
I HAVE A PRO-2096 DIGITAL TRUNKING BASE SCANNER. IT HAS WORKED FINE BUT NOW IT READS " ALL CHANNELS LOCKED OUT " NEED HELP
need to do a RESET. Then try your local WX frequency to verify it works. The RESET will wipe out all existing programming, just to warn you. Check your manual, or RadioShack.com for details.
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Need police channels for butler mo
http://www.radioreference.com/apps/db/?ctid=1485 Make note of radio reference.com......This is probably the best resource for frequencies in the United States - and it's free! It is particularly helpful with info on digital trunking and how to program your pro 96 for your specific area. Where I live in Wake County, North Carolina EVERYTHING is now trunked digitally and I found radio reference very helpful.....Happy scan ning!
Oct 17, 2009 | Radio Shack Pro-96 Scanner
V-scan channels missing
Sounds like all that is happening is that the channels are locked out, you need to go through manually and unlock them. I have the same scanner and that is what I needed to do.
Feb 12, 2009 | Radio Shack Pro-96 Scanner
How do I unlock a channel that I previously locked out on accident by hitting the wrong button and how do i see the locked out channels
go to the channel by pressing manual,then the channel number,then manual again,then press LO or lockout, and scan
Jan 18, 2009 | Radio Shack Pro-96 Scanner
Channels locked out
Mrs. Santa brought me a new PRO-97 yesterday. I'm new to this - just wanted an aircraft frequency scanner, but got the whole shameal. I had a bad AC adapter and attempted to fix the power problem as directed in the manual by re-initializing the scanner. That blew all memory away.
I received the feared All Channels Locked Out message and through a little research and fiddling, realized the scanner was pre-programmed. An Addendum came with the scanner with instructions to reload the 155 pre-programmed frequencies:
1) Turn off the scanner and then turn it on again.
2) When 'Multi-system Trunking Scanner' appears, press PGM.
3) Press 1.
This will reload the pre-programmed frequencies erased by the re-init. Press scan and it'll be as new as outta the box!
Best wishes,
Farnk
Aug 16, 2007 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-96 Scanner Logo
334 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
xxxxxx xxx
Steve Allison
Steve Allison
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
