Question about Maytag MDG7600AW Gas Dryer
MAYTAG GAS DRYER TUMBLES BUT NO HEAT (FRONT LOADER 6 YRS. OLD)
Dryer tumbled for an hour, did not shut off, opened door and clothes were cold and wet. Maytag Dependable Care plus, Mod # LDG8604AAE
  • bhollerman Apr 06, 2009
    As above, same problem.
  • Anonymous Mar 19, 2014
    The start button on the dryer is buzzing when i press it to start the dryer. The dryer is not running. Any ideas on what id wrong.
  • 706 Answers
Hello maryfitgera,
It certainly sounds like you are not getting a flame established in your dryer. That can be one of several components such as a non-resettable thermal fuse, gas valve assembly or control relay to that gas valve assembly. Unless you are well versed on how to work on these kinds of components, I suggest you just call in an appliance tech or.. let me know if you want to attempt diagnosing and repairing it yourself. Be advised that there are elements of danger in so doing. Let me know how you want to procede on this and I'd be happy to walk you thru it..
Regards,
Rick
Posted on Nov 24, 2008
Tumbles but does not dry
When you put your wet cloths in the dryer close the door. You should then turn on the dry cycle you wish, not the fluff option as there will be only air and gas dryer will not heat the cloths. Wait 30 ~ seconds after the dryer is turned on and listen for the gas to ignite and begin warming and drying the cloths. If you hear no bump sound like the ignition of the gas, then you have an ignition issue. It will require replacing the ignitor. All the best and good luck. Hope this helped.
Oct 02, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Clothes do not dry even though unit runs, tumbles, times, but blows out cold air through vent. Maytag de90-3060406
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 23, 2011 | Dryers
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
No heat from dryer
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 03, 2009 | Amana ALE331RAW Gas Dryer
Dryer runs, tumbles clothes, but does not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 09, 2008 | Maytag SDG4606A Gas Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
502 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
