Question about Polycom SoundStation
Polyspan soundstation power supply schematic diagram
I have a soundstation which reacts stangeley (does not han up) and see some components that wer overheating in the Power Supply. Does anybody have the schematic diagram of that power supply?
I would be very grateful.
Best regards
Thierry
  • Anonymous Mar 19, 2009
    cannot get the polycom soundstation to work. Problem with the wire hookups
My Polycom sound station power unit malfunction. I found that AC transformer broke. If I try to get substitute transformer, what is the required ac output (Vac) and Amp that I need to find?
Posted on Aug 22, 2010
Schematic atx diagram
I give up! Why would you need a schematic for a computer power supply? I've been in the computer business for over 30 years and have never needed a power supply schematic. Just curious!
Sep 18, 2013 | Antec BP350 350-Watt Power Supply
POWER SUPPLY NOT NORMALblinking
If you have a schematic diagram of the power supply you would have to check for the feed back circuit which comprises of an error amp and an optoisolator check around that circuit and change any faulty component that should solve the blinking condution and thus will bring on the power supply
Dec 29, 2010 | Philips 20PT6441 20" TV
I need to change the transformer inside the power supply. can you tell the the output voltage?
You need a meter to test the voltage else check the manual or normally it is written on the transformer about power,voltage and current.Hope this helps.
Jun 25, 2009 | Polycom SoundStation Accessories:...
POWER SUPPLY BAD, NEED SCHEMATIC DIAGRAM COMPONENT LEVEL
Polaroid will not release component schematics not even to service centers as they are designed to replace the entire modules while under warranty out of warranty there is very little Chance of obtaining new replacement parts. As i have a 2006 LCD and a 2007 Plasma Polaroids and polaroid told me they are considered a disposable TV replacement parts are not available and suggested that I try ebay
Apr 29, 2009 | Televison & Video
I need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Jan 30, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
Need schematic diagram, some advice and ultimately replacement parts
You have something in short circuit in power supply pattern, so filter coils are burnt. It may be voltage regulator, or regulating transistor, electrolytic capacitor or even shorted diode at pwr. input serving to protect in case of inverse polarity applied. Check all for short. Was it reverse polarity or overvoltage occured?
Mladen,
mladen@propilots.net
Mar 18, 2008 | Lowrance GPS
Noise on the recieving line
1-change telephone cable from your machine to wall outlet if the problem fixed it is ok,if not you must contact your phone company because noise may be in telephone line itself.
Feb 18, 2008 | Polycom SoundStation
Polycom soundstation Ex - no dial tone
Someone in our office recently damaged the RJ-45 cable for our Polycom Soundstation. Because the jack was damaged I could not determine the order of the cables. After a call to polycom, we found the pinout information we needed - so I thought I would share, in case anyone else finds themselves in a similar situation:
With the RJ-45 prong pointing down the wires, from left to right are:
  • Black
  • Brown
  • Red
  • Orange
  • Yellow
  • Green
  • Blue
  • White
Then Crimp and test. I got this information directly from Polycom for use with the Polycom Soundstation. This information was not easy to get. They originally told me they could not provide the information and I would have to buy a power adapter. This is not true, just trim the cable and follow the above instructions.
Sep 14, 2007 | Polycom PCY220016000001 SoundStation2...
Polycom SoundStation Logo
1,700 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
