Question about Solar 2-wire Pull Chain Light Switch For Ceiling Fan Lights
Pull switch wiring !!
It has com and 1 way ,2way fitting the switch where do's the live go and where do's the nautral wire go ? can you help pls
  • 333 Answers
Connect the black wire to live. and the white wire to neutral. I hope this will help you.
Posted on Nov 24, 2008
Which wires is the hot wire, nautral and ground because I have a three prone plus changing it to a four prone in the back of the dryer.
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Oct 29, 2010 | Hotpoint NBXR463EBWW Electric Dryer
Need wire colour of live feed to revese light to fit reverse warning unit, thanks
i,m trying to find a live feed in the boot of my bmw mini cooper s, it,s a 04 plate can any one help pls
Aug 14, 2010 | 2009 Mini Cooper
FITTED REPLACMENT POWER ARIAL TO SHOGUN IT WORKS BUT RETRACTS WHEN I SEARCH FOR STATIONS. OLD UNIT HAD 5 WIRES BUT NEW HAS ONLY 3. I PUT LIVE TO BATTERY AND SWITCHED LIVE TO SWITCH WIRE EARTH TO BODY.
yeah this happened to me but sorted it. live to battery for the blue find power anntena wire on back of stereo [ usually blue] connect, black wire earth to the body. the 2 wires are for the half mast switch - just blank them off.
Aug 07, 2010 | 1999 Mitsubishi Montero
Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
Downstairs toilet light switch needs rewiring
Yes, run a black wire from connector (a) to one terminal of your new light fitting if you are installing a metal fitting you will need to connect an earth wire also.
If you are reusing the same pull switch and it is still connected as you describe then the floating end near the light is probably the switched live conductor, so you could connect this to the live terminal of the new light. but be careful it may be live.
Caution always disconnect the power before working on electrical wiring.
Please remember to rate this solution.
Dec 07, 2008 | Electrical Supplies
WIRING PULL SWITCH
yes but be sure to turn the power off first a switch is basically a break in the active wire so put your pull switch as being that break glenn.....
Nov 22, 2008 | Electronics - Others
Pull cord switch
If it is a 1 way switch circuit (2core +earth cable) it should be LIVE/HOT in COM and Aux live (to the light) in L1 . I
f you have a 2 way circuit (3 core + earth cable) the aux strappers go in L1 & L2. and LIVE/HOT to COM
Remember to disconnect the power before working on electric wiring.
Oct 15, 2008 | Electrical Supplies
Solar 2-wire Pull Chain Light Switch For Ceiling Fan Lights Logo
210 people viewed this question
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
