Question about Philips Magnavox 20MS3442 20" TV
I have a phillips tube t.v that shows a wavy horizontal line
When the tv is first turned on it displays a wavy 3 to 4 inch horizontal line, but after its on for a little while it will show the full screen but still goes in and out at times, has anyone else had these type of problems?
    Scholar:
  • 188 Answers
If the set works fine intermittently it may be a loose connection or a bad solder joint. More likely the later. Heat will sometimes make a cold or broken solder joint work. If this changes when you lightly tap on the side of the TV you have a bad connection of sorts inside. These repairs can be expensive unless you find a good repair person.
The syncronizing signals in TV's (keeping the picture locked in) are around the high voltage transformer which is usually the heaviest component attached to the circuit boards. It's stressful over time and I've seen the solder connections crack and become intermittent.
Posted on Nov 23, 2008
There is a horizontal line halfway 3/4 across the screen, it's not black it's just a different color.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 14, 2016 | Vizio E500i-B1 50-Inch 1080p Smart LED...
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Any idea on what is causing these issues with Vizio TV? Black lines horizontal, shadow vertical.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD TVs will be similar, irrespective of its screen size and brand.
Jul 27, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Can I see the difference
Visually, there is very little difference to the eye of the average consumer between 720p and 1080. However, 720p can deliver a slightly smoother-looking image, due to the fact that lines and pixels are displayed in a consecutive pattern, rather than in an alternate pattern.your tv is display format is 720p and blu ray is 1080p. what happen is it will be scaled into 720p. old tv set format is 480p 720p represents 1,280 pixels displayed across the screen horizontally and 720 pixels down the screen vertically. This arrangement yields 720 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another. 1080p, on the other hand, represents 1,080 horizontal lines displayed sequentially. This means all lines are displayed during the same pass. 1080p is the highest quality HD display format. 480p represents 720 pixels displayed across the screen horizontally and 480 pixels down the screen vertically. This arrangement yields 480 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another.
Apr 05, 2009 | Samsung Televison & Video
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Grey screen, white lines
adjust your screen at the back of tv flyback down you see the fucos and screen adjust the sreen ok
Nov 06, 2006 | Panasonic CT-36G34 36" TV
Philips Magnavox 20MS3442 20" TV Logo
163 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
