Question about Indesit W 123 Front Load Washer
Door of indesit washing machine no opening model no WM12X
Hi I wonder if you can help, my washing machine door is not opening.
After it had initailly started a wash I forgot to put something in so stopped the machine and waited to so I could open the door. To be honest I think I was a bit heavy handed, now it won't open at all. I have switch off and left for a while. The handle appears slightly loose as well.
Can you please advise on how best to fix this problem.
Thanks
Lynda
  • jaygo70 Nov 27, 2008
    My Indesit W103 door handle has snapped off! Now I can't open the door at all, I have tried putting it through another wash to see if that released the door but to no avail - help!
  • 333 Answers
First thing if this unit has an electric lock you probably open the door at the wrong time and threw it out of sync. First try to do another load from the beginning cycle and let it finish. If this don't work unplug your machine and then try. I hope this helps you.
Posted on Nov 23, 2008
Indesit washing machine model IWD 7145S says F06 on display and all lights are flashing. its at the end of wash and door wont open
Hi Sammi,
Have a look in the troubleshooting guide of the User Manual Should find some information to help you there. Good Luck,
Jack:}
Nov 17, 2012 | Indesit Washing Machines
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
I have a indesit wm12x washing machine and i was told it is a dryer but i can not get it to work please help
I have been looking at your machine on internet and found out that the indesit model you have is not the washer dryer version it is a washing machine so has no dryer function. hope this helped.
Sep 19, 2010 | Indesit W 123 Front Load Washer
Manual for intergrated indesit wm12x washing machine
To obtain the instructions for washer, go to,
WWW.INDESITSERVICE.CO.UK
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Indesit W 123 Front Load Washer
I need to replace a washing machine door seal (indesit wm12x). Do i need to remove the top or can i do it from the front ? Any other tips on the procedure would be great. Thanks
It would be adviseable to rempve the top, and also tilt the washer to the rear, as it makes it easier to change the seal, and gives you more room to get your hands in.
Please rate my comments.
Thanks.
Oct 30, 2009 | Indesit W 123 Front Load Washer
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Regards
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
Help!! Indesit WM12X - cold wash only
Yes, they are easy enough to replace, but you need to test them with a multimeter to see if they are faulty..
There could be other things wrong.
Nov 22, 2008 | Indesit W 123 Front Load Washer
I have a indesit wm12x,and the door will not open. i think the handle spring has gone because the handle is loose and the door is stuck. could someone please tell me how to open the door. thank you
you can open it from the inside, take the lid off ensuring its disconnected from the mains, u will see the back of the door catch unit (with a torch). i managed to open mine with a screwdriver :)
Mar 29, 2008 | Washing Machines
INDESIT WM12X
brushes in your motor almost certainly, put your meter across the motor you will find a open circuit failinf that your control module could be damaged
Apr 21, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
321 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
