Question about Amana Heating & Cooling
Trouble shoot amana gas furnice - Amana Heating & Cooling
  • 306 Answers
Is the flue fan coming on? Is any thing working. Need problem
Posted on Nov 23, 2008
  • Ken Bledsoe Dec 17, 2008
    what was the problem? ken
The little door that opens to let water into machine(front loader) does not open. Why?
Links to sears parts direct. First link is to download manual, see page 11 Clean dispenser.
NFW7200TW10 AMANA RESIDENTIAL WASHER Manual
Second link is to parts diagram. images can be changed in size.
Second image from left is the dispenser.
AMANA Residential Washer Parts Model NFW7200TW10
Sears offers trouble shooting help also look for trouble shooting in user manual.
Sep 21, 2014 | Amana Front Load Washing Machine Washer...
Fix error code amana dryer
The best method is to do your home work and find error code list and service manuals inside dryer or Google it online with your model number find error codes as most are online and you must do total trouble shooting procedure and replace defective parts if necessary and after you plug the dryer it should reset it self
If dryer did not reset in other hand if error code persist you still have problem and problem could be main board issue
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 08, 2013 | Amana Dryers
Pilot gos out when burner shuts down wall furnice
Usually thats a sighn of a bad thermocouple,thats the copper tube that goes from the gas valve to the actual pilot assembly it senses that the pilot is burning and allows the main burner to light. If there is no pilot lit the bur will not light. Its there to keep you home from exploding from a release of gas with no pilot. The good thing is that most ofthem are universal and most water heaters use the same one. And you can buy one for a water heater at lowes or home depot for about ten bucks. If you get one thats longer than the origional thats ok because you can just coil it in a circle just be carefull and dont kink the tube,if you do kink it you must get another one. even if you straighten it.
It wont work. Hope that gets you going and warm.
Jan 12, 2013 | Vanguard International Blue Flame - Medium...
Oven lights but does not get hot enough
My oven lights, but takes for ever to heat or will not heat at all. Anyone know how to trouble shoot the issue?
Jan 07, 2013 | Amana ACS3350AS Gas Kitchen Range
BLOWING WARM AIR
Amana portable model AP148DS blows air turns on but will not cool.
Jul 10, 2010 | Amana Portable Air Conditioner
My element turns on and the gas will light ocasionally.
If the igniter is glowing and even sometimes lights the burner, it's not the igniter that's bad. I've created a checklist that most homeowner's can use to trouble shoot dryer lighting problems. Click on my username, scroll down my profile to my tips and tricks for trouble shooting gas dryers.
Hopefully, one of these tips will solve your problem. Good luck.
May 18, 2010 | Amana NDG2330AW Gas Dryer
Tapan furnice not turning on, The furnice start and the lighter turn on the small fan is running and after about half a minute the first eye turn on for a second and then everything stop
Check to make sure the gas valve is on.
If so it is most likely the heaqt sensor that proves the ignitor is on. Replace the sensor.
Next time post your model number, answer will be more precise.
Oct 10, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
