Question about Brother GX-6750 Typewriter
Typing the same letters
I have a Brother AX-10. I have the ink and the wheel with the letters. I plug the typewriter and when I type it's always the same letter, because the brown wheel with letters isn't rotating.
(Don't know the correct names for the material. Sorry.)Any solutions?Thanks.
  • reiskings Nov 25, 2008
    Probably it's a problem with the printwheel. So how exactly do I install it correctly? And do I reset the typewriter?
  • reiskings Nov 26, 2008
    Solved the problem! I bought a new daisy wheel and it's working just fine but when I tried to replace the ribbon cartridge couldn't do it. How do I do I replace the ribbon?
  • 183 Answers
Check to see if anything is interfering with the free rotation of the printwheel, ribbon or corr. tape if improperly installed may do this. with the mach. OFF move the printwheel by hand. if it moves ok, and it still won't print wright, you will need a repair shop to fix this problem.
Posted on Nov 24, 2008
My AX -430 typewriter was functioning well as i was using it. However as i was typing a new word, the letters are no longer visible on the paper. The part that hits or is it the hammer or arm, can no...
It sound like you have a broken part. If the hammer is not hitting hard enough, the armature theat make the hammer strike the keys is broken. This is a common problem with the ax's
Mar 03, 2011 | Brother EM-430 Typewriter
If you are not in proportional space or a KBII you probably have a broken P/W homing pawl.
Jan 24, 2011 | Brother ML-100 Typewriter
Brother AX 24 Daisy Pinwheel. Lock it in start typing goes okay for a while and then starts typing letters different than what is typed. Any clue as to what to try to correct problem?
Remove the printwheel, rotate it manually look for bent or broken spokes, if they are allright try using the T/W without a correction tape. If this works you may have a tacky L/O which catches the P/W.
Sep 28, 2010 | Brother Office Equipment & Supplies
Check to see if there is a switch on the left side of keyboard for international or symbol printwheel selection.
Jun 17, 2009 | Office Equipment & Supplies
Typing wrong letters on Brother SX-4000
Try hitting [CODE] + [RESET] at the same time to reset the cartridge. Make sure the cassette is installed correctly.. the "ear" on the cassette should always be on the upper right.
Mar 24, 2009 | Brother SX-4000 Typewriter
Not typing any letters
the printhammer/wheel may not be latched into place. there is a black lever on the right side of the printhammer. you pull it towards you to remove the printwheel and forward to latch it into place. otherwise the machine will probably need repair, or just go to a thrift shop and you can pick one up for $10 to $25 dollars. just plug it in and try before you buy.
Nov 12, 2008 | Brother GX-6750 Typewriter
Typewriter ax-10 by brother
Turn off machine. Unplug machine for at least 1 minute. Plug back in and turn machine back on. If it still doesn't work, check to see what typing mode it is in, and change it if necessary.
Sep 05, 2008 | Brother GX-6750 Typewriter
Nakajima AX-60
check you type wheel ,and clean your optical reader ,optical reder read`s your typewheel and because of some dirt sometimes printer moves a type wheel one step forward and you get a II.
May 11, 2008 | Office Equipment & Supplies
Brother GX-6750 Typewriter Logo
108 people viewed this question
James Cagle
James Cagle
Jim Keysor
